Bought the baby one did you.
Yes, small parts, limited service amperage and lack of 3 phase
<Draw tube, why would you not attach a stop to a draw tube? Because draw tubes move so your stop will move. >
That part I understood
my concern was the big warning sticker at the draw tube actuating mechanism warning about "dead length stops" killing the system. Just wanted to be sure my plug gage pulled against the spindle did not fall into the "dead length stop" category.
<Yes machine flats on anything that does not have a flat if you want to clamp it with setscrews in the holders.>
I thought there must be another way to hold the collet holders in the tool holder otherwise you would think that for $150.00 they would machine some flats on the collet holders. My dumb.
<Why use a constant reference point for Z zero? Why not use the end of whatever part you are machining. I simply set the tool offsets to the end of the stock; take a facing cut with the first tool and then simply touch all the other tools against this faced end.>
Those of us that came to CNC late in the game usually find learning CAM software the lesser of two evils. With CAM software establishing a GXX is elemental to the process. CAM software also allows you to set up unlimited templates for the operations you do frequently. These templates carry along all the tool locations nose radius, etc, as well as the basic tool movements like face, rough, finish, etc. You can bring up the template, apply it to your previously drawn tool path and off you go. I was hoping I could establish a common Z reference point to set tool lengths from for tools that needed to be added to the turret for whatever operation I wanted to do. Maybe I'm spoiled by the way the mill works. Anything in the changer shares a common length offset, why not use the same approach with the lathe turret?
Please do not construe the proceeding to be an advocacy of, or sales pitch for, the use of a CAM system.
<You mention Donkey, have you noticed Donkey done disappear?>
Anyone who enjoys communicating as much as Donkey does will not be gone for long, I hope. Take you and Donkey away from the Haas forums and things would get pretty sparse.
<That is enough rambling for now.>
