586,119 active members*
3,558 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > NEE - AMC Control on Onsrud Router
Results 1 to 15 of 15
    Nov 2005
    172
    I am working with a company who purchased a circa 1999 Onsrud Router with an NEE AMC control. I do not work on these brand controls or machines and the company advised me they are getting poor response from the manufacturer for assistance. Does anyone have an electronic document on this control? Operators type reference. Essentially they need to know how to home the control, call over programs, edit, etc.
    Any help would be great! Email to [email protected]
    Thanks!
    Mark T.
    Jun 2006
    76
    I don't have any electronic documentation for the AMC but I an running a 2004 Onsrud with AMC controller.
    Homing the machine is done during startup. Pull the e-stop and the controller will fire up. Once it's gone through it's strartup procedure it should prompt the user to datam the machine. At that point the machine should datam all axis.
    Transferring NC files is done from a pc networked to the machine. I use Cimco as an editor and transfer program. Once the program is loaded into the machine it can not be edited.
    Feel free to email me if you want to talk more. jason (at) mwdsgn.com
    Nov 2005
    172
    Thanks Jason - I was able to work with them and develop processes to home the machine, call over programs, etc. There was limited information on this control available online.
    Mark T.
    www.cnccustomservices.com
    Mar 2012
    AMC-4 Controller
    I have a Onsrud 96 C10 made in 2000 but the documentation no longer contains the controller (AMC-4) manual. I need help with the serial connection, baud rate, data bits, stop bits, and Parity:Flow Control. Does anyone have any information on this.
    Thanks!
    Nov 2007
    7
    Hello all,
    i have a lot of documents, docs and manuals concerning AMC4. Even a software called AMCutils. All is compressed in a rar file here : AMC.rar - 4shared.com - online file sharing and storage - download
    Hope it helps
    Michel
    Mar 2012
    Got Them, Thank You.
    Brett
    Feb 2010
    8
    Hi!
    I know you're post is quite old, but I am looking for information on the AMC2 controller. Is any of your documentation still avaialble?
    many thanks,
    Irving
    Quote Originally Posted by rmetoile View Post
    Hello all,
    Hope it helps
    Michel
    Nov 2007
    7
    hi irving,
    here is the link : AMC - Download - 4shared - michel rigaud
    hope it will be helpfull
    michel
    Re: NEE - AMC Control on Onsrud Router
    rmtoile, I downloaded your 4share file and it was very helpful with all of the contained documents! Do you also happen to have the WinAMC software? I see the AMCUtil software in there but not the WinAMC.
    Shaun
    Nov 2007
    7
    Shaun,
    sorry but i don't have winamc
    michel
    Mar 2016
    4
    hi irving,
    michel
    Hi, do you have a program to communicate for the AMC4 controller? because the winAMC it's not more exist, do you know how to download?
    Luis
    Mar 2016
    4
    Thanks for the information, do you have a WinAMC software?
    Apr 2017
    6
    someboday can repost the 4shared files ??
    i have a lockformer with AMC4 controller but no manual and no software
    i have test with hyperterm , burny bu no luck for sending a file , i have a error in test serial 1 : FIFO error
    Feb 2016
    8
    Hello all,
    Hope it helps
    Michel
    I too am interested in getting the user's manuals for the NEE AMC4. If you post them again, I can work on posting them somewhere more permanent so you won't have to be bothered anymore.
    I'd appreciate it!
    Dec 2023
    4
    Hello everyone... I realize this thread is very old, but this is the only thing i have found on the entire www that is close to solving my problem. I have a 2004 Onsrud Panel Pro 5x16 with the AMC pendant and the NEE controller. I do not have the original computer that was connected to the machine, so i too need to set up a terminal and figure out how to talk to this ancient machine. Anyone with any clues as to where to find the correct terminal software and how to config the serial connection, baud rate, data bits, stop bits, and Parity: Flow Control, etc. I can’t find a copy of WinAMC anywhere. I was able to find a terminal called CoolTerm, but I still can’t figure out what all the config settings need to be to make it work. I may just need to know the serial connection settings; Baud, parity, etc, but I also need the Post Processor for the CAM software to generate the GCode specific for the machine configuration. Can someone please help?
  1. CR Onsrud vs Thermwood CNC Router Units
    By dgraf in forum CNC Machining Centers
    Last Post: 06-15-2018, 03:50 PM
  2. axis exchange for Onsrud Router
    By RSIBG in forum DIY CNC Router Table Machines
    Last Post: 08-15-2011, 08:07 PM
  3. Replies: 0
    Last Post: 08-10-2008, 12:10 AM
  4. Onsrud CNC Router question
    By CJH in forum Commercial CNC Wood Routers
    Last Post: 07-18-2008, 03:07 PM
  5. Onsrud Overhead Router
    By marksnwv in forum Open Source CNC Machine Designs
    Last Post: 11-18-2006, 06:18 PM
