586,121 active members*
3,086 visitors online*
    Apr 2007
    11
    Start macro with input button
    I have made a macro for release of my tool. It contains several operations. I also made a button on my screen that executes the macro. But now I want to use an external input button to execute the same macro. How do I do that?
    I tried the OEM 301 and it works but lets say I want to execute several macros with different inputs, how do I do that?
    Is it possible to connect an input to an hotkey? Because then I can give my screen button a hotkey, or am I wrong?
    Nice forum!
    /Georg
    You assign the hotkey in Screen4, then, in ports and pins, set an OEM Trigger for the external input and assign the same hotkey as the button.
    Apr 2007
    11
    How do I assign a hotkey to the OEM Trigger? In the System Hotkeys?
    Ports and Pins, I think. Input Signals page.
    Apr 2007
    11
    I have tried the hotkey tab in the Input Signal page but it seams to be for emulating the input with the hotkey. Or am I wrong?
  1. Need Help for Mach 3 Macro+Start by ext.Button
    By Morianer in forum Mach Software (ArtSoft software)
    Last Post: 07-16-2009, 08:15 AM
  2. Can spindle start when you hit the Z-axis button?
    By moldcore in forum Milltronics
    Last Post: 04-26-2009, 02:14 PM
  3. Shopmaster start/stop button died
    By sexton in forum Shopmaster/Shoptask
    Last Post: 07-28-2008, 05:12 PM
  4. Physical Button Signal Input Triggering Macro
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 08-25-2006, 04:26 AM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
