586,069 active members*
3,554 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Poor speed on stepper motors..
Results 1 to 9 of 9
    May 2006
    309
    I bought some used 6 wire unipolar stepper motors on Ebay and mounted them on bipolar drivers, but I can only run them on low speed.
    I have set the drivers on 8 micro steps. Will they do better if I change this to 4 or 2 micro steps? Or will it be better for me to buy bipolar motors or maybe unipolar drivers?
    Are there any way I can test the motors? Maybe the guy sold me some bad junks which has been overheated.
    May 2007
    380
    What voltage are the motors? What voltage are you running them at? Are they stalling? More details on your setup will help a lot.
    John
    Details on the motor and driver will help.
    If the inductance is high on the motor, you will need lots of volts to get them spinning.
    Quote Originally Posted by jaru-eri View Post
    Zapp Automation Ltd
    www.slidesandballscrews.com
    May 2006
    309
    I use cnc_box 3977 and I think I need to adjust the current. There is also an attenuation mode setup that allows me to choose between 3 options, see picture:
    Which of these three should I choose? And how much current do I need for full coil connection on the steppers? My drivers can get up to 2.5A My motors is unmarked, but hey are nema23 and I think the full torque must be at least 200 oz-inch. I use 24 V on these.
    What speed are you getting? Without the data on the motor it is hard to say what speed you should be getting.
    Does the motor get hot?
    you are making your own driver?
    Zapp Automation Ltd
    May 2006
    309
    The driver is cnc_box 3977 See: http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
    I can´t set the speed to more than 20-30 inch/min before the motors halt. The motors don´t get hot but I think the current potentiometers on the drivers must have been pre-adjusted to the half, so maybe that´s the problem.
    20-30 inch a minute? What is this in RPM of the motor? what is the lead of the screw?
    Zapp Automation Ltd
    if the current is only half what the motors need then you will only get half the torque so that would make a differnence.
    Zapp Automation Ltd
    Jun 2003
    3312
    Ahh, six wire motors...see, make sure you have your current set correctly, a common mistake:
    http://pminmo.com/six-wire-motors
    http://pminmo.com/which-stepper-motor
    Rapids will depend on screw and load also:
    http://pminmo.com/mechancial-power
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  1. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  2. Wanted DIY stepper driver circuit for 6 wire stepper motors
    By Colin300 in forum Australia, New Zealand Club House
    Last Post: 09-21-2007, 03:20 AM
  3. stepper motors or servo motors?
    By jprobst in forum Torchmate
    Last Post: 07-13-2007, 11:37 PM
  4. Stepper motors are still going at the incorrect speed. Need help with Mach3
    By Apples in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 12:29 AM
  5. Changing the speed of DC motors
    By creative_mind in forum Community Club House
    Last Post: 12-02-2003, 02:27 PM
