586,754 active members*
7,619 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cinci Arrow w/2100 Siemens 611 error
    Aug 2008
    4
    Siemens 611 Drives configuration error Alarm: 39-21
    Also it says to check the MAI options list?
    Any help would be great.
    Thanks.
    :drowning:
    Aug 2008
    4
    Anyone have any info? Still lost on this one.
    Oct 2008
    123
    ARROW ERROR
    Hello I have come across this problem on 3 occasions and it is not an easy one to sort out over the internet. it will be long winded and frustrating.
    first question what has caused it have you changed the hard drive?
    what is the schematic drawing number of the machine? ( this is the bottom number on the silver label on the outside of the cabinet door ). do you have an a4 folder in the electrical cabinet? i will need to know what is in your MAI option list on the control.
    press more
    system configuration
    purchased options
    you should now see an applet for MAI options
    i will also need good photos of the TOP row of components in the electrical cabinet.
    the MAI option content must correspond with the top row of components otherwise you get the error that you have.
    please send any info to [email protected] if you want to proceed. i will try my best to help ( i have succeeded in the other cases ) but i was at the machines which helps.
    regards
    mallardfizz
  1. retrofit on a cinci arrow 750 vmc.
    By chaz6966 in forum Machines running Mach Software
    Last Post: 02-26-2009, 06:01 AM
  2. retrofit to a cinci arrow 750 machining cntr.
    By chaz6966 in forum Mach Mill
    Last Post: 02-21-2009, 11:33 PM
  3. Acramatic 2100 Arrow 1000 need help
    By griz-shop in forum Cincinnati CNC
    Last Post: 12-06-2008, 07:49 PM
  4. Cinci Arrow 500
    By Clawsie Machine in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2008, 10:48 AM
  5. How can I DNC to Cinci Arrow 500
    By Clawsie Machine in forum Mastercam
    Last Post: 11-20-2007, 02:36 PM
