586,547 active members*
3,296 visitors online*
    May 2007
    20
    Upgrade to powerfull laser lamp (WkLaser)
    Hello,
    I've a LC1280 with 80W lamp bought from Wklaser and I'm wondering to upgrade it with a more powerfull laser lamp. I know that I will change the power supply and probably modify the machine so the lamp can fit.
    Did you know any site that sell laser lamp/power supply?How much can I improve Watts?150W?200W?
    Many thanks and sorry for my english
    Paride
    Dec 2008
    1258
    You could upgrade to a 120W or perhaps 150W, but often the solution is to use 2 tubes and combining optics. I would suggest to look at the RF excited lasers, you would get better performance and life - but of course the cost if higher.
    Zax.
    Feb 2005
    469
    Paride,
    Email wklaser.com They should be able to fix you up with a more powerful tube and matching power supply, and they can tell you if anything else is needed. Also check ebay.
    Skip
    Smile
    Paride,
    You can do this no problem,
    Look at changing to 120 w and power supply,
    Make sure you have a good chiller.
    Also ask about the 10,000 hour 150w tubes I am trialling these they will cut 3mm acrylic at 5.5 mtrs per min:banana:
    Fastest I,ve seen for a while
    Thanks Chris
    May 2007
    20
    Quote Originally Posted by hpc laser u.k View Post
    Paride,
    Thanks Chris
    I've asked Wklaser for more powerfull tube and the suggested me the 100W tube because 130W could cause some problems (why?!).
    Can you tell me where I can find 150W tube and supply?!What machine did you have and how works these tubes?!
    Many thanks
    Paride
  1. GE 388 Lamp
    By lgreeves in forum Fanuc
    Last Post: 02-01-2010, 08:20 PM
  2. Upgrade from 60W to 80W laser tube
    By bibi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-28-2008, 08:56 PM
  3. Makino FNC 60 spindle lamp
    By jasnooks in forum Uncategorised MetalWorking Machines
    Last Post: 05-26-2008, 03:23 PM
  4. Would this motor be more powerfull than my current one?
    By radicooldude in forum CNC Machine Related Electronics
    Last Post: 05-20-2005, 05:59 AM
  5. Neon indicator lamp question
    By The Wizard in forum CNC Machine Related Electronics
    Last Post: 05-01-2005, 04:28 PM
