Well , that's what my father always said and so did an artist friend of mine a few days back.
In order to do that i need to step away from the obvious way of buying stuff especialy for building a router, since on that path it will take years before anything gets built at all because of the finances.
So it's back to basics, i spent a few days working out a design for a CNC-router that i can build entirely from commonly and localy available material, like 100x50x5mm rectangular tube and 40x40x4mm square tube.
Something that is widely available over here, some of it even at the local metal recycling facility.
If i can get it there it's durtcheap, otherwise it's still quite affordable.
It has to be a gantry type thing because i want to be able to add a rotation along the X-axis or a rotational table in the middle in the future
I don't have a 3D CAD program like Solidedge , but i do have access to lightwave , a 3D modeling and rendering program, which will do just fine for this.
So here's what i came up with so far:
only a few parts need to be machined on my small milling machine the rest is a matter of a metal saw and a drilling.
The milling motor is going to be a Kress FME 1050.
I'll use 25mm supported rails with linear ballbearings for guideance and TR24x5 trapezium screws for motion, which will be replaced with 25 mm ballscrews in time.
No running support needed since the screws will be shorter than 1000mm between the bearings.
The Horizontal Beam, it's support, the legs of the Gantry and the bridge are 100x50x5 mm rectangular alluminnium tube.
The 90 degree angles i basicaly achieve by putting in 90mm long pieces of 40x40x4 mm square alluminnium tube.
This will also neatly close the ends of the tubes.
At least that's the plan.
I am not an engineer, but i think this will do the job, if not , i can replace the 40x40x4mm Tube with solid alluminium.
Obviously any help and/or suggestions will be appreciated at this stage.
Especial concerning construction (like i said, i'm not an engineer).
