586,385 active members*
3,468 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Huanyang HY02D223B goes POP!
    Jan 2006
    628
    I was running a job the other day when I heard a loud POP!, and noticed that my spindle was slowing down. I walked over and hit the EStop, and sure enough the display on the VFD was off. There's wasn't anything obviously wrong (ie. no smoke, no flames, etc).
    I wasn't sure what happened, so I thought that maybe it was just the breaker. I checked the panel and the 20A breaker had been tripped. I looked at all my connections and everything was tight.
    So, I flipped the breaker back on and went over to the VFD. When I applied power to the VFD, the breaker for the entire 100A panel clicked off! Oh boy. I'm not sure what happened, but the VFD is toast. I'm going to send it back to China for replacement, but I'm seriously thinking about upgrading to a Hitachi XJ200 or SJ200 as my primary VFD.
    Any thoughts on what happened? Any ideas? This has functioned flawlessly for 6 months, running small jobs all the time. No problems at all until now.
    Steve
    Dec 2007
    379
    Cant really help but, I have purchased the X200 3 hp VFD for my 2.2kw Chinese spindle instead of the Huanyang one out of the fear of reliability problems. After all, the price difference between the two VFDs is small. I'm knew to all this so I am trying to figure out how to set it all up. I guess the only disadvantage is that most on the zone seem to have the Huanyang and there is not as much forum support if you are a newbie.
  1. Help with Huanyang HY02D223B
    By stevespo in forum Spindles / VFD
    Last Post: 02-01-2014, 09:42 AM
  2. Help Help Help - Huanyang VFd and spindle
    By PsychoPig7 in forum Phase Converters
    Last Post: 06-19-2012, 09:54 AM
  3. Huanyang HY02D223B 2.2Kw VFD
    By gillyhyde8888 in forum Phase Converters
    Last Post: 09-12-2009, 12:46 AM
  4. HY02D223B and GDZ-10 PLS HELP
    By 15mgtar in forum DIY CNC Router Table Machines
    Last Post: 08-21-2009, 06:32 AM
  5. Could someone post there setting for a HY02D223B
    By Ed Williams in forum DIY CNC Router Table Machines
    Last Post: 05-20-2009, 06:23 PM
