I have been chasing a problem and I can't find it. My holes are larger on top than bottom when I cut them. The top is .02 inch larger than bottom of hole on a 20mm hole. This machine has linear bearings and ball screws on all axes. There virtually no backlash on all axis's".0005" or less. This just started happening and I have used this machine 2 years. Little over a month ago I put one of these Chinese spindles on it. It worked great. But I have checked everything out and run out on spindle bit is a little over .001. The spindle seems good and tight. But could the spindle be doing something different when it’s under a load?
Thanks Ed
