586,108 active members*
3,163 visitors online*
Results 1 to 7 of 7
    Nov 2008
    6
    Confusing diagram
    Can someone double-check this for me:
    I am about to wire my stepper motors bipolar(p) (them and the drivers are just in, I don't have my power supply yet)
    Yet (me being new to these kind toys) I am confused about the wiring. I've got myself these babies: Datasheet
    following the datasheet at the bottom there is a (what seems to be) fool-proof wiring diagram for bipolar(p), yet I am confused by the "full step, parallel bipolar"-table at the top.
    The fool-proof diagram suggests me to combine:
    Blue/White + Red
    Red/White + Blue
    Green/White + Black
    Black/White + Green
    Yet the "full step, parallel bipolar"-table is talking about other wire combinations..
    Appart from that which combination of wires will be A+ and which A-?
    And finally (pfew): Is it ok to twist the wires in pairs? Esthetically it looks much better but maybe it becomes to hot or something else that I don't know about.
    Jan 2007
    146
    the fool proof way is wiring for bipolar parallel which generally gives you more torque at higher speeds but needs more current. Conversely bipolar series gives you more torque at lower speed and uses half the amps. Sometimes you wire bipolar series if your driver cannot output enough current.
    you need to hook up one set of coils to a+ and a- and one set to b+ and b-, sooo
    a+ = Blue/White + Red
    a- = Red/White + Blue
    b+ = Green/White + Black
    b- = Black/White + Green
    I would think it is ok to twist the wire pairs, if your wires are getting hot you like have too light of wire.
    Nov 2008
    6
    Thanks for the answer jschmitt.
    But it's still not clear to me what the "full step, parallel bipolar"-table is about, because if I combine blue/white+red (like we both came to the conclusion from the fool-proof diagram) how should I read that table? For example: it's not possible to power blue/white + red/white at step 1 simply because they aren't combined.
    I hope someone can clear that up for me : )
    Feb 2009
    2143
    Does this help or hurt?
    Link
    Nov 2008
    6
    Thanks for the links but I've already encountered those in my search these past few weeks ; ) I knew what the effect was of serie or parallel wiring, yet I was confused by the Datasheet since it gave me 2 ways (or atleast that's how I see it) to wire these motors bipolar(p).
    so.. it doesn't matter if i connect them like this:
    Blue/White + Red
    Red/White + Blue
    Green/White + Black
    Black/White + Green
    or this:
    Blue/White + Red/White
    Red + Blue
    Green/White + Black White
    Green + Black
    it will both be bipolar(p)?
    Doesn't the direction of the magnetic field affect the motor?
    Or am I totally misinterpretating the "full step, parallel bipolar"-table? Should I just forget about that table and stick with the fool-proof diagram at the bottom?
    Jan 2007
    146
    I see what you mean, I just looked at the diagram and the wire colors. As long as you make sure the coils are not crossed between A and B you should not hurt anything.
    Connect like this.
    Zapp Automation Ltd
    www.slidesandballscrews.com
  1. Confusing Z Home
    By bullethead67 in forum Waterjet General Topics
    Last Post: 09-22-2009, 12:46 AM
  2. DATA BIT 8 AND 7 CONFUSING
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-24-2009, 11:08 AM
  3. BobCad-Cam V21.5 is confusing
    By jessey in forum BobCad-Cam
    Last Post: 05-24-2009, 10:43 AM
  4. A Very Confusing Coontroller ? Problem
    By MoonlightMedia in forum DIY CNC Router Table Machines
    Last Post: 07-31-2006, 01:06 AM
  5. confusing of backlass or backlash
    By saptoro in forum Uncategorised MetalWorking Machines
    Last Post: 03-08-2005, 10:12 AM
