586,069 active members*
3,425 visitors online*
IndustryArena Forum > CNC Electronics > UHU Servo Controllers > Current Schematcs & support information
Results 1 to 6 of 6
    Jan 2006
    297
    Here's a the most current information on schematics,parts lists, parts revision,etc. Current Schematic I don't believe there's a current schematic with out some errors/changes. Here the best I can do. in the original UHU drive forum, complete schematic to rev.0B, post#1652. Power stage schematic to rev.0C, post#1690, Parts modification for Under 11amps continuous & 0ver 11 amps continuous, post#1887. and finely most current parts list, in the thread "Revised Bills of Material for HP UHU Drives" is the "UHU HP Revised Parts List 9-22-09.xls‎" is the latest & most accurate parts list showing all parts revisions as of today.
    Hope this helps
    Paul :drowning:
    Jan 2006
    297
    Schematic, Current rev. B + rev c for power stage
    Post #1 still is the correct information for the latest schematic support
    Jan 2006
    297
    Current Schematics
    Let's try this again. Hopefully here's the schematics for the UHU.HIGHPOWER
    PCB
    Attached Thumbnails Attached Thumbnails img042.jpg   img043.jpg   img044.jpg   img045.jpg
    Jan 2006
    297
    wrong wiring on img.041.JPG, J8-J9 previous post
    I just noticed that the above drawing is labeled WRONG. see the enclosure with this post for the correct hook up. the drive shown is an old one when I was mounting the 470uF 200v capacitor on the P2 terminals due to a height clearance problems
    Jan 2006
    297
    this is the closest to a accurate schematic 7/24/2012I
    I think the above schematic the closest to a current schematic to what we're building
    Aug 2006
    2758
    Re: Current Schematcs & support information
    New Modified HP_UHU current limit circuit schematics.
    High Power UHU Thread (HP.UHU) (post # 40)
    On the old schematics (Rev 1.0), attached to this thread, replace C28 (4.7uF) by a 2.2uF/25 v film capacitor, replace C29 by 470 pf ceramic capacitor and don't forget to connect the R16 lead to +15Vdc instead of +5Vdc.
    regards,
    kreutz
  1. Replies: 0
    Last Post: 07-27-2013, 06:44 AM
  2. Max length for an acme threaded rod. End support or fully support the frame?
    By dlpaul in forum DIY CNC Router Table Machines
    Last Post: 03-12-2011, 09:54 PM
  3. Low Current interface, High Current Motor?
    By Clackvalve in forum CNC Machine Related Electronics
    Last Post: 05-13-2010, 06:42 PM
  4. Information
    By Davey in forum MetalWork Discussion
    Last Post: 05-04-2006, 12:00 AM
  5. Please a need an information
    By giansa in forum Uncategorised CAM Discussion
    Last Post: 11-26-2003, 11:24 AM
