Hey All,
I just finished setting up the PCNC1100. And I am getting an error when i run the FIRSTPART.NC program.
The error:
After the tool change I get the following error:
MACH3SCRIPTS (dialog box) Error on Line: 2 - unspecified error
When i close the box, the program continues without starting the spindle and i get a debug box that opens and says:
M3.m1s - DoSpincw()
WHAT WORKS:
- Manual spindle control works
- starting spindle from MACH3 by clicking on the SPINDLE ICON will start the spindle through MACH3 and run it at what ever rate is entered into MACH3
- all axis move properly
- as far as I can tell everything else works
Any ideas on why the spindle will not start? Here is a copy of the G-code, so you don't have to go a look for it. I included only the first few lines, as the coordinates for the tool path seem to run fine.
=======START PASTE=========
(FirstPart - Ver 8 Sept 08)
N10 G20
N15 G00 G17 G40 G49 G80 G90
( 0.25" End Mill )
N25 T1 M06 G43 H1
N30 G00 G90 G54 X0.9243 Y-2.2832 S1000 M03 <----- MACH3 ERROR on this line
N40 G00 Z0.2 M08
N45 F15.
( MILLING TEXT )
========END PASTE==========
Any help is appreciated, thank you in advance.
Brian
