Requested feature is there a way that you could make a script command from your
Run time Estimation \ program extents so as to insert xy size into program as note if so with the ability to round up to a fraction.
I’ve been playing around with scripts to reformat current files to a new machine and Ncplot’s ability to use scripts is a God send.
Also in Run time Estimation \ estimated run time \ average feed rate, allow feed rate to be edited here instead of in file only.
I also noticed that the {alt}-{F}-{X} shortcut is listed as Export DXF and as Exit
And one more request this one my be a stretch but is it possible through a new feature or through a script function to select multiple lines of txt and replace one line of txt with selected txt in active file through NcPlot. I’ve been copy and pasting to do this and would like to do this with a script
I have code written that uses sub programs and my new/used laser cutter does not call sub programs from in the active file like my other 4 machines so I copy and paste the same sub code multiple times to convert code.
I’m new to vbscript so not sure if there is script code to do this in an active program like NcPlot
I'll post some of my scripts if anyone is interested, might inspire someone in there work
PS I’m using version 2.07
