586,104 active members*
3,378 visitors online*
    Dec 2004
    312
    at5 25 wide timing belt tension?
    im wondering if any of you know what tension the at5 25mm wide timing belt should be set at and how do you check if its set correctly? using those tensioner tester? is there a cheap verison of that stuff?
    Dan
    Mar 2006
    2712
    Try Gates' online engineering tech pdf.
    Dick Z
    DZASTR
    Dec 2004
    312
    url for that? i did email brecoflex (where i got my belt from) to get more info
    Mar 2006
    2712
    Try these: www.gates.com/drivedesign
    http://www.epi-eng.com/rotorway.../r...elt_issues.htm
    Might have to mess around a bit, "google" the epi thing.
    Dick Z
    DZASTR
  1. BMC20 Belt tension for servo drive?
    By RoundieLand in forum HURCO
    Last Post: 05-08-2009, 08:46 PM
  2. Belt Tension Options??
    By flash319 in forum DIY CNC Router Table Machines
    Last Post: 09-19-2007, 08:06 PM
  3. Timing belt tension requirements vs backlash
    By jensor in forum Mechanical Calculations/Engineering Design
    Last Post: 05-20-2007, 08:04 PM
  4. Belt Tension Adjuster Design
    By mxtras in forum Mechanical Calculations/Engineering Design
    Last Post: 05-16-2005, 04:33 PM
