This was my Saturday project. My motor has alway run a bit hot but I recently had to replace my motor control board in my Grizzly G8689 X2 and my motor now runs fine but was getting even hotter. With the new board my rpm's went up to 4900 too so I'm happy about that part.
So since I run programs for hours and some times all day and all night, I decided to take care of this problem once and for all.
The pics pretty much tell it all, I made a "water jacket" that slips onto the motor. I turned the motor to true it up and clean it then turn rings with grooves for O-rings on the inside. The outer case is 4" exhaust pipe.
The coolant runs into the bottom, fills and circulates around the motor then discharges from the top and into the Loc-Line and finally out the nozzle onto the endmill and part.
Needles to say I was thrilled when on my first test there were no leaks !
So I'm going to run a program that will take about 6 hours to complete and see how it does. I expect it will keep it cool and all will be fine.
I finally did get my tapered roller bearings adjusted properly and I'm very happy with them, the head get to about 110* and stays there on long programs, I don't think that's too bad.
Here's the pics...
