586,103 active members*
3,268 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Tool length offsets
    Jul 2009
    10
    Tool length offsets
    how do i measure the tool lengths without a tool presetter.
    Apr 2006
    3206
    Who here has the luxury of a presetter??
    Assuming the old Fadal control (rather than the Siemens, or..) just bring up the tool offset page, hit option #4, and follow directions, starting at 1.
    Bring the tool down and have a gage block or whatever standard you use on the Z Zero, and slowly increment the tool to the block (recommended you start with the tool below the block and step the tool up) till the block barely slides under the tool...and hit Manual. It'll prompt you by loading the next tool to do it again, or be ready to exit out of the function.
    To proof the program, use Mass Modify and add an inch, or two, or more to your offsets, dry run the program, then re-do your Mass Modify by subracting the same value and you're ready to run.
    Jul 2009
    317
    Jog the tool to a gauge block,
    type: SL,1
    do the same with the rest,,sl,2,3,4,,,,,
    900
    gbpacker--
    Call the Maintenaince Technologies Chastworth Center (Fadal Factory Support) and our PRogramming and Application guys can talk you throught it. BTW-- There is no charge for telephone support. (818 727-2100 option #3)
    Neal
  1. Fagor 8055 tool length offsets
    By bobcor in forum G-Code Programing
    Last Post: 12-02-2010, 02:30 AM
  2. G43.1 - Tool Axis Direction Tool Length Compensatioin
    By EngTech in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2007, 11:01 AM
  3. setting lathe tool length offsets on ah ha control
    By machinewerks in forum G-Code Programing
    Last Post: 02-28-2007, 04:09 AM
  4. Tool Length offsets supported?
    By HomeCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-01-2004, 05:38 PM
