586,082 active members*
3,518 visitors online*
    Mar 2004
    1661
    Anyone in Sweden running step/dir servos?
    Is here anyone in Sweden, close Stockholm, that uses step/dir servo drivers? I have problems with my machine with loosing position and need to make a test with another driver.
    Anyone who wants to help a guy in need?..
    Jul 2007
    887
    I'm not really close to Stockholm but I guess I could send you a drive to try with if a better solution doesn't pop up - if I have one that matches. What type of motor are you driving? PMDC, Brushless AC etc? What voltage and current?
    Things to check, in case you haven't already:
    Is the polarity of the step- & direction signals correct (ie. active low/high) and is the wiring done accordingly?
    Do you have enough current to drive the opto-isolators in the drive (if opto-isolated).
    Is the pulsewidth long enough?
    Are you losing on all axies or just one?
    /Henrik.
    Mar 2004
    1661
    Thanks Henrik. Believe me, A LOT is tested.
    DC (brush) motors.
    if someone has a servo it could be good to try a different driver/servo combination.
  1. Running Mach3 with a Step four router
    By B-Sure in forum Mach Software (ArtSoft software)
    Last Post: 05-29-2022, 04:41 PM
  2. Hello out there from sweden
    By woodo in forum European Club House
    Last Post: 12-23-2008, 12:41 AM
  3. Another New from sweden
    By MagnusLundback in forum European Club House
    Last Post: 06-05-2008, 02:42 PM
  4. Hello from Sweden
    By Oyster in forum European Club House
    Last Post: 05-31-2008, 06:35 PM
  5. Replies: 6
    Last Post: 03-06-2004, 05:11 AM
