586,110 active members*
3,257 visitors online*
    Aug 2006
    102
    Troubleshooting Help
    Guys I have an intermittent problem with my router that hopefully others may have had and diagnosed. Looking for any assistance / tips to assist with the debug.
    SETUP
    Its an 06 Joe with Gecko Vampires and a Mini I/O from CandCNC using Keling 570oz-in steppers. Running Mach. The Gecko's have heat sinks and fans on them. The router has been running flawlessly (other than operator error) for 2 years.
    I bought this setup to transport to a bigger and better router as time/energy permits.
    PROBLEM / SYMPTONS
    Recently it was running and I heard a loud bang (scare the crap out of you loud) whereby both the x and y directions stopped moving. After a 1-2 seconds both axis started up and kept going although loosing a significant amount of steps. This problem has repeated itself a few more times usually materializing after several minutes of cutting.
    WHAT I HAVE TRIED
    Assuming an intermittent power problem caused by loose connections I "giggled" all of the power/step/direction connections on the Gecko's while running a program in the air (not the safest thing.. I know). No issue found
    Assuming some type of stepper problem I ran a program at 200% feed rate override (300 in/min). No issue found
    Checked all connections to power supply ect.. nothing abnormal.
    WHAT I AM LEANING TORWARDS
    -Intermittent Power Problem?
    -Overheating of a GECKO?
    -Software interference on PC?
    -Failing breakout board?
    Any other suggestions / hints?
    Apr 2005
    462
    my first thought was power supply issue?
    Aug 2006
    102
    In case anyone has a similar problem I have tracked this down to a loose heatsink on my X Gecko which was putting the Gecko into some type of thermal shutdown.
    The clip on the heatsink never fit well from the start and it must have loosened over the last year. I cut 1 row of fins off the heatsink making it a little smaller and now it fits very well and the router is running reliably again.
    Jul 2008
    267
    Do you use thermal grease between your heatsink and Gecko?
    Jun 2003
    3312
    I wouldn't think it's a gecko thermal issue, as that would in all probability manifest as one axis, not 2 at the same instant. The big bang would almost make me think you had a filter capacitor fail if your using a linear power supply. But I would expect that to be physically viewable. But i'd tend to look real closely at my power supply first.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  1. Linistepper troubleshooting
    By pedro13 in forum Open Source Controller Boards
    Last Post: 02-13-2009, 07:05 PM
  2. TMC-1000 Troubleshooting Help
    By 44 Echo in forum Benchtop Machines
    Last Post: 10-07-2008, 10:03 PM
  3. RS232 Troubleshooting
    By gar in forum Haas Mills
    Last Post: 08-02-2007, 12:48 PM
  4. troubleshooting buddy
    By EvanB in forum Commercial CNC Wood Routers
    Last Post: 04-03-2007, 02:28 PM
  5. CNC Code troubleshooting
    By sinnfeinan in forum Mach Software (ArtSoft software)
    Last Post: 11-13-2006, 02:05 PM
