x2 cadcam.
Also, fyi, drive surfaces and check surfaces: Drive surfaces are the surfaces your toolpath will be cutting, while Check surfaces are surfaces that are next to the surfaces your toolpath will be cutting. (Surfaces that the tool may touch while cutting the drive surfaces.) You can specify the distance you want to force the tool to stay away from the check surfaces, say +.010" or even -.125" if you want. Or you can not use them at all.
HTH
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
