586,116 active members*
3,469 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > All axis will not move
    Jul 2008
    13
    Hello , i have a fadal with a siemens 840 d controller. We just got this machine so im not too familiar with it. Everything was working fine and now the x,y and z will not move. The numbers on the screen are moving as normal when trying to jog. But no axis will move. This started after a day of using it. The machine is presently not at its home position, i can not bring to home position due to not being able to move any axis. The feed is not at 0. Tried restart, reset, shut the machine completely off. There is oil and air pressure. Everything seems to be normal on controller. Any help would be much appreciated.
    thanks,
    Dec 2008
    3109
    Do you have any switches ON on the front panel ?
    "Machine lock" would disable any axes from moving but allow the readout to simulate movement and run graphics for program checking
    Sep 2009
    181
    Check the door switch? Did you close the door?
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
    Jul 2008
    13
    The only thing i have selected is the mpg, to jog it. The doors are closed. I have tried all options for the axis to move in small increments to large increments. I also keep making sure the feed is not at zero. Its wierd bec it shows the coordinates are moving on the screen but its almost like the x,y,z are all stuck....??
    Sep 2009
    181
    PM me your phone number and I will try to walk you through it.
  1. What method did you use to move the x-y-z axis?
    By widgitmaster in forum Polls
    Last Post: 07-04-2013, 04:49 AM
  2. Y axis dont move
    By oneeye in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-25-2009, 06:16 PM
  3. how to move the Z axis on a pendant
    By cob in forum Mach Mill
    Last Post: 12-18-2008, 09:49 PM
  4. how to move the Z axis
    Last Post: 08-23-2008, 01:56 AM
  5. G91 B axis move?
    By DocHod in forum G-Code Programing
    Last Post: 11-02-2007, 05:56 AM
