586,652 active members*
2,681 visitors online*
Results 1 to 6 of 6
    Mar 2007
    108
    Exclamation Hurco retrofit!
    I guess I am ready to retrofit my Hurco KM3. I want to use the same servos/ incoders. Would like to use Gecko drives. Would like to use CNC4 PC breakout board. I have E C servos. They run at 80 volts. Would like your advice. The reason to go with this setup, is I have people that have used Gecko & CNC4PC near here. I wont start till the snow flies. Thanks for your input.
    Dave
    Jun 2009
    4
    I'm about 2/3 of the way into the exact same project using the exact same recipe (KM3P, Gecko 320X, CNC4PC, stock servos+encoders, bailing wire, duct tape, bubble gum, etc.)... kind of a headache, but fun... hope to have it running by next week...
    Feb 2007
    592
    Question Why waste good hardware?
    I would use the OEM Servo amps and powersupply.
    Control it via a Mesa 7i43 card with a 7i33 PWM to +/- 10V analog card.
    $200 gets you back in business using EMC2 - More $$$ and more time if you go the Mach3 route as they have not finished there 7i43 driver yet last I heard.
    Oct 2008
    78
    Emc2 and Mesa cards are the way I when on my SM1 used the orginal motors and drives.
    Jun 2009
    4
    Hurco KM3-P retrofit
    Dave, after a lot of problems and several late nights, I am finally up and running. Just doing the finishing touches- spindle speed control, limits, etc., but Mach3 is driving the mill. I have only run it manually by jogging from the screen and I'm having a blast! I will be cnc'ing in no time!
    How is your project progressing? Have you torn into the machine yet? I ran into a lot of little issues that slowed me down, but knowing now how to handle them, I could do it much faster if I did it again. Your parts list (from your first post) will work well if you can get everything sorted right. I can give you details of my build if you would like....
    Mar 2007
    108
    Smile
    I haven't done anything yet. Just got it in a temp. controlled room. Going to have both knees replaced Monday. Looks like it will be a late winter project.
    I would like details, pixs. ect. The hard part is to keep some wiring, and get rid of the rest. My e-mail address is [email protected] Live in Logansport Ind. Been an Hamradio operator since 1960.
    dave
    Quote Originally Posted by mikeysformula View Post
  1. Hurco Tm-5 retrofit??
    By pimpbike in forum HURCO
    Last Post: 04-12-2009, 12:01 AM
  2. HURCO mill retrofit
    By Larken in forum Viper Servo drives
    Last Post: 10-07-2008, 02:07 AM
  3. Hurco KMB-1 Mach3 Retrofit
    By jalessi in forum HURCO
    Last Post: 08-19-2008, 03:19 PM
  4. Considering Hurco retrofit
    By beartrax in forum HURCO
    Last Post: 08-13-2008, 02:38 AM
  5. Retrofit on Hurco
    By Steve@Reliance in forum HURCO
    Last Post: 02-07-2006, 07:28 PM
