586,108 active members*
3,288 visitors online*
Results 1 to 6 of 6
    Oct 2006
    47
    System 3r magnetic chuck questions
    Hello, I am new to EDM machines and will have a few questions over the next few weeks. I just picked up a Hansvedt Journeyman 201e. I have the original operators manual for it.
    My first question, does anybody have a link to any specific info about the operation of the system 3r magnetic chuck mounted to the machine Z axis.
    Thank you for any links or explanations of how it works.
    Frank
    Sep 2008
    117
    Can you post a picture(s)?
    Gene
    Oct 2006
    47
    Yes, I will try to do that tomorrow when I get back in town.
    Frank
    Oct 2006
    47
    This is the chuck that I have.
    Any operating info would be apreciated.
    Frank
    Oct 2006
    47
    I should add that the main reason I asked for info is due to not seeing an obvious difference in magnetic force at the face of the chuck with the lower half removed. (split apart by removing the 2 clamps on the outside dia.)
    Frank
    Oct 2008
    11
    its an electromagnetic chuck, it is powered by wall plug or source from the machine. Lite should come on when you turn on, and other lite comes on when chuck is energized, check fuse if no lites come on, check connectors and cables.
    RWK
  1. Walker Magnetic Chuck Schematic
    By CharlesM479 in forum CNC Machine Related Electronics
    Last Post: 01-04-2010, 05:21 AM
  2. Magnetic Chuck Strength?
    By keebler303 in forum Uncategorised MetalWorking Machines
    Last Post: 07-20-2008, 01:41 AM
  3. Magnetic Chuck Doesnt Hold
    By Smrtman5 in forum Uncategorised MetalWorking Machines
    Last Post: 12-20-2007, 06:15 PM
  4. Magnetic Chuck for Milling Machine...?
    By tdfsu in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2007, 08:41 PM
  5. Brown & Sharpe Permanent Magnetic Chuck. 5" X 10".
    By dertsap in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 10-13-2006, 01:26 PM
