586,108 active members*
3,038 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Anyone ever use floppy disk drives?
    Mar 2005
    76
    The old 5 1/4 drives have nice little steppers in them. And the board to control it. I have tried hooking up an old PS/2 5 1/4 floppy drive positioning stepper up to the parallel port, using the step and direction connections, and grounding the motor on terminal. But no luck yet.
    I get the pulse train from the port so I know that is working. Any ideas?
    The motor locks when power is supplied to the drive PCB.
    This is a very nice web site. And some really sharp folks on here. Glad I found it.
    Feb 2004
    2337
    Welcome John. Glad you like it here. There has been a few posts in the past regarding those small steppers. From what I remember reading, they are just too small to drive a machine of any useful size.
    From what I have seen, to buy bigger steppers is not that expensive, especialy if you buy off ebay.
    Being outside the square !!!
    1695
    Ynneb is correct. I started out using these motors. They are fun to get started with and might work on a very low friction system, but they are far too weak. The friction on a 1/4" threaded rod can cause them to miss steps unless you're going really slow.
    To check if your board is ok, connect a wire to the step input and alternately touch +5v and ground. The motors should move.
    Mar 2005
    76
    Thank you for the information.
    Haven't had the time to play with it again. Plan on using another drive controller, other than a PS/2.
  1. Floppy disk drives
    By Wjman in forum DNC Problems and Solutions
    Last Post: 08-13-2014, 06:49 AM
  2. Floppy CNC Router (on the Cheap)
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 03-03-2005, 08:09 PM
  3. Floppy Drive Cable Fiasco
    By Al_The_Man in forum Computers / Desktops / Networking
    Last Post: 11-25-2004, 06:53 AM
  4. newbie AC Servo question
    By GalaticDan in forum Servo Motors / Drives
    Last Post: 10-31-2004, 05:25 AM
  5. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
