587,028 active members*
3,151 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > RF45 Clone CNC Z axis question
Page 1 of 2 12
Results 1 to 20 of 28
    Oct 2009
    I'm in the process of gathering information to CNC my RF45 clone mill.
    I have a question about the Z axis, once it has been changed to ballscrews and servo drive, etc. When there is no power to the Z axis servo motor will the head fall? If it doesn't does this put stain of the ballscrews? Thanks
    Jun 2004
    6618
    I'm pretty sure it would fall without power. The head is pretty heavy. The nuts on some ball screws will spin down sometimes under their own weight. Consider the extra few hundred pounds added. I have a similar mill in conversion now, but round column. I was considering ordering the square column for it. This particular issue was part of the equation on that decision.
    There are several ways to counter the issue though. Several counterweight systems have been documented on the Zone.
    Lee
    Feb 2007
    4553
    Post
    Ellis76,
    They make a servo with a brake option, when you power up the machine it applies 24 volts to the brake and unlocks it.
    When the power is off the brake is locked so the axis wont freewheel.
    http://www.isa.org/Template.cfm?Sect...ContentID=9489
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Oct 2009
    Thanks guys. I'm guessing most of the machining will be done in the X and Y direction and the Z axis will be held in position by the power of the servo. Is it better to have a brake applied when the Z axis is not moving to save current draw through the servo z axis motor? Would this be quite high(the current) just holding the head there?
    Or am I just making this more complicated than it needs to be and people typically park the head @ the lowest position when the machine is off and let the Z axis servo just take care of it during production? And some would add a brake just in case of a power failure? Thanks
    Feb 2007
    4553
    Post
    Ellis76,
    Conserving power may be good reason to have a brake however it is usually not implemented for that reason.
    If you where working on a part and decided to pause the operation and turn off the machine a brake is a good idea because you would not loose your Z zero or Z home position.
    The same scenario would apply during a eStop.
    Jeff...
    Jun 2005
    152
    I just had this same question as I am putting precision ground ballscrews on my IH mill. I was advised it wouldnt need a brake. I tested it last night and it definately wont need a brake unless your gib is all worn out (and only maybe then). Even disconnected from the ballscrew the head barely moves and thats with me forcing it and my gib oiled up and completely loose.
    Devin
    Feb 2007
    4553
    Post
    Devin,
    On a RF45 style machine the Z axis dropping may never be a issue because of the design of the ways.
    On a boxed way or linear rail machine it would be a big issue.
    Jeff...
    Apr 2007
    2580
    I dunno about the IH machine but.....
    MY Lathemaster cnc mill has a Z axis ballscrew setup and it definitely does fall when power is not applied. I have also lightened the head considerably with a belt drive conversion. It can fall but it is kinda slow and if you let it, will pick up speed and could damage the head. I am right now running my gibs pretty tight on the Z and I just gotta remember when I shut off the machine to tighten the gib locks a touch before I throw the switch. There are a lot of people who use an electric brake which is energized to disengage when the power is on so the head can move but when the power is off the brake engages locking the head in whatever position it is in. I am running a 3-1 ratio on the Z and I understand the IH uses a 4-1 ratio so this may be why it does not fall as easy? not really sure. If your gibs are smooth and in good condition and adjusted properly they should really not hold it up too well so I am not sure of that comment. Even if it did hold it I would be wary of trusting the simple sticktion of the gibs and ways to hold it up for overnight. It might actually slowly fall... I intend to install an electronic brake as others have done eventually but I am still working on the enclosure and other items right now. This is the best option I think wether or not your head stays put.... JMHO....peace
    Jun 2004
    6618
    I agree that if the dovetails are in proper form, they should not allow the head to stay in a raised position. I suppose if the ball screw is higher pitch count and geared up pretty well, then I can see it.
    Regardless though, something should be used to prevent accidental drop. The brake sounds good. I'm sure that's how high end machines do it. There is however an added benefit to using a counter weight. That is that you won't need near the gearing or motor size to gain respectable movements. The motor would be assisted in raising the head. Lowering already uses gravity.
    Just another thing to consider.
    Lee
    Apr 2007
    2580
    That is what I thought too initially.....
    But now that I have my Z working without a counterweight I do not currently feel it is necessary. I can get the Z moving at near 150IPM and it changes direction very quickly. Of course I am using some VERY stout 1125 oz inch motors at the max the Geckos will run them.... A counterweigt system is nice and will definitely help but you also have to consider that even tho the weight is now even or close to it you now have to deal with the inertia of that whole mass changing direction... Just a thought....
    In reality, barring some serious use of 3d profiling at very high speeds the head never really has to move that quickly. Nor does the table for that matter, I can get rapids of ludicrous speed and I have backed it way down because I am prone to fat fingering stuff on the computer so I gotta be careful, however yesterday night I ran a little engraving program which can and did run at a nice feedrate and even that was nowhere near what it is capable of.... When I was designing this system I was very concerned with max rapid speed and acceleration but in real use at least for me right now and I am sure well into the future I have my max rapids set at 100ipm and even that is probably overkill.... Let's face it the table only travels like 30 inches either way so what do you need stupid fast rapids for? The Z axis is even less important to me, right now I have my toolchange position set 5" above the work zero and it gets there in a hurry.... Maybe if this was a large router table I would worry about it but on this relatively small machine it is PLENTY fast....
    The Z axis head is Real heavy especially with the gears and original motor still on there and as one poster said a ballnut will just roll off a vertical ballscrew. If your gibs are so tight that the head does not fall without the screw attatched to the millhead then your gibs are indeed TIGHT!!! If the ballscrew was not there with it's associated pulleys and belt drive atop I am quite sure my millhead would come crashing down onto the table with some serious force.... The gibs would have to be quite near a lock tightness for it to hold up there.... I never weighed the millhead but I am no small fellow and without the cast iron framed motor on there and not including the Z axis slide I carried the millhead across the shop one time and let me tell ya I could not wait to put it down!!!! What is that saying if you plan to lift an elephant you had better have a place to put it down ready, well that goes double for an RF45 millhead!! peace
    Jun 2005
    152
    Quote Originally Posted by jalessi View Post
    Devin,
    Jeff...
    I only refer to an rf45 in my post. Not sure why you mention the other styles, I guess I missed something in the post, but agree with you that a different style mill would definately need a brake.
    Feb 2007
    4553
    Post
    Devin,
    The reason why I mentioned the other types of mills is because 99% of the larger mills would have big problems without a brake on the Z axis. Either that or the gibb needs to be tightly locked before shutting the machine off like Pete mentioned.
    As Pete already stated if the operator forgot to lock the gibb the head may end up dropping and causing some serious damage.
    Not everyone reading this post has your mill.
    Sorry to be so confrontational, ask Lee he will tell you its my nature.
    Jeff...
    Sep 2006
    1738
    Like other have said, I think a counterweight system would work well along with maybe a compression spring system.
    -Jason
    Jun 2005
    152
    Devin,
    Jeff...
    No problem with the confrontation Jeff, but this thread is about an RF45 clone/type mill and so is my post. If someone makes the rather large jump to thinking that my post applies to all mills everywhere (even though I only mention mine), then there comes into question their ability to operate a mill in the first place.... opposable thumbs etc.. (c;
    sidenote: everything above is typed with a smile.
    Devin
    Jul 2005
    When I took apart my machine, I got the approx. weights: Head 170 lbs. Motor 40 lbs. Slip saddle (my manual calls it that) 20 lbs. for a total of 240lbs.
    I have a brake on my machine and have the key removed because I don’t have a 24V power supply for it yet. When the axis in disabled, I sometimes get about an 1/8” of downward travel. The other day I removed the drive belt and the head freewheeled down and crashed into my presetter. The gibs are a little loose and if I had to do it all over, I’d omit the brake. I’m not sure about the accuracy for maintaining position when the motor is turned off but sometime, I’ll check it out.
    I also do not have a counterweight and can achieve about 250IPM (only 150 on X/Y because of a lower voltage power supply).
    Apr 2007
    2580
    WOw man....
    Ya got a video of that millhead going 250IPM?!! I can get around 150IPm and that is TOO fast for me.... are you running Geckos? When I get too much faster than that the Gecko faults during a direction change and the bad part is that the head will fall when it does..... You must have a very powerful system, what is your belt drive ratio? Motor size? power supply voltage? Inquiring minds wanna know.... Almost hard to believe....peace
    Jul 2005
    I’m with you-I think the only time I want a rapid like that is when the head retracts for a tool change and 150 should be just fine. During development of the tool position routines, I’ve been using 150. The mill is a Lathemaster ZAY7045 with Aerotech hardware with 300W brushless servos running at 80V(X&Y) and 160V (Z). My belt ratio is 3.5:1 and the leadscrew pitch is 0.2”. I spent about $300 on the leadscrew but it’s a new Kuroda ground screw. I have cheap angular contact bearings and in the future may replace them or just by a decent CNC. But for now, the learning experience is fantastic. I have a lot to learn and I’ve only made 2 parts. Sometime I’ll post some videos but I am still setting things up and need to research what would be a safe upper limit for the rapids. The 250IPM varies from 240 to 300(once only for a few cycles) and I still need to find the right parameters.
    Can you put a brake on your Z axis so when the Gecko faults it stops the head? What voltage are you running? Maybe your acceleration is a little too high when the motor windings warm up due to the higher speeds.
    Tray
    Apr 2007
    2580
    Tray....
    Man that is really fast, especially on the factory millhead. What the hell is aerotech hardware? 160vdc!! Holy smokes!!! No need for a counterweight with that much power for sure.... I am running Geckos at their max recommended 76vdc. My motors are 1125oz inch. I am also using a .2 x3/4 inch ballscrew on the Z. My millhead is considerably lighter than it was stock due to a belt drive conversion and higher HP much lighter spindle motor. See my build thread on here entitled " Finally Getting Started"
    I am probably going to get a brake for the Z when funds allow. The acceleration is set pretty high and that of course does not help the direction change problem but as I said it only does that when I try to run it at 200IPM or more.... I am sure if I set the acceleration much slower I could get a higher feedrate but as I said before even 100IPm is plently even for a toolchange for me on this mill... Mine is also a Lathemaster Zay7045l.. Have had it for nearly nine years now and still working great!!!! peace...
    Jan 2007
    277
    Quote Originally Posted by devincox View Post
    Devin
    If you guys both know that its obvious some added detail in a reply doesnt really apply but maybe that item still has some general educational value why dont you just let it slide instead of arguing about it?
    Im 42 years old and It seems like a more laid back mature method of discussion here at cnczone would be helpful.
    Feb 2007
    4553
    Wink
    Quote Originally Posted by davo727 View Post
    A brisk discussion is good, it keeps you on your toes.
    Arguing come on, you must be kidding. That would never happen here.
    Jeff...
Page 1 of 2 12
  1. RF45 clone CNC conversion
    By GMitchell in forum Uncategorised MetalWorking Machines
    Last Post: 09-08-2009, 05:50 AM
  2. My New RF45 clone CNC conversio finished!
    By GMitchell in forum Vertical Mill, Lathe Project Log
    Last Post: 06-13-2009, 03:44 AM
  3. RF45 Clone CNC Conversion Started
    By Bird_E in forum Benchtop Machines
    Last Post: 05-10-2009, 08:27 PM
  4. RF45 clone with a DC motor
    By hdj80 in forum Charter Oak Automation Support Forum
    Last Post: 05-29-2007, 11:01 AM
  5. X3 or RF45 clone?
    By logjammer in forum Benchtop Machines
    Last Post: 12-14-2006, 03:34 PM
