586,070 active members*
3,449 visitors online*
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Oct 2011
    Bavelloni EGAR 323-5 AXIS
    Hallo i need your help...
    I had problem with the repair NUM BOX (motherboard)and now this is ok
    but the machine dont work the EGA FILE to complete the program (the TOOLS page is ok to NUM BOX-the pointer 253 TOOL/N..its ok- the work of supions cup with pointer its ok..........with the same ega program).
    NOW the machine with the same ega program dont work auto to take the tools
    and give me errors..--54. parameter error E30000 900102--.
    The CNC is for marble/granite.
    Please if someone knows something about let me known.
    Thanks a lot from begin.
    .Attachment 149691
    Attachment 149692
  2. #22
    Hi Nikos
    I'm afraid I cannot help you much since I'm not working with a Bavelloni machine anymore. But it might be that there was a tool still present in the spindle before you changed the motherboard, so I think you might need to find a way to reset the tool store so there is no tool selected.
    You might be better of to email Bavelloni directly the error code you get, they will be better able to help you.
    http://stonecoldcnc.com -> Over 1600 FREE DXF templates for sink, basin and lavatory cut outs for Granite and Marble countertops
  3. #23
    Oct 2011
    Thank you very much.....for your HELP!!!!!!!!!!!!!!
    Tomorrow contact the Bavelloni...
    Best regards
    michailidis Nikos
  4. #24
    Nov 2018
    5
    Quote Originally Posted by stormi View Post
    Hi, I could really use some help with this mashine.
    I stopped the machine while it was changing tools and the head of machine left standing in that position. After I started again I couldn't do anything... So I switched to manual work and and move the head... tool dropped down (tool is free and OK) BUT When I wanted to start it again machine refused, and I got an error message: !!tool ejector open!! , Now when I wanted to turn back to automatic work I get an error that the tool is ejected.
    I tried to manually put the tool back, but it doesn't work. In the user manual, the solution for this problem is blank. Please help.
    Hi i have the same problem , you need to look into the clamp ,from down of head , clamp have 4 sigment , them close the tool , so if one of them not closed correctly , its broken
    Only one solution , chang the clamp , wery dificult operetion , hou is doing this need to be profesional
Page 2 of 2 12
  1. Bavelloni Tech
    By Yarvin in forum Glass, Plastic and Stone
    Last Post: 03-09-2023, 02:05 PM
  2. Needed software for Z.Bavelloni Alpa/100 CNC
    By aealaa in forum Glass, Plastic and Stone
    Last Post: 07-29-2021, 07:20 PM
  3. z Bavelloni egar 323-5n
    By KIRILL33 in forum DNC Problems and Solutions
    Last Post: 10-31-2013, 03:10 PM
  4. bavelloni
    By marktill in forum Glass, Plastic and Stone
    Last Post: 09-25-2010, 03:52 PM
  5. Bavelloni ALPA 315 4C_Tool Problems
    By cyntanada in forum Glass, Plastic and Stone
    Last Post: 10-10-2009, 11:24 AM
