586,106 active members*
2,981 visitors online*
Results 1 to 13 of 13
    Jun 2007
    15
    step/direction to +/- 10v (analog)converter
    Hello everyone.
    I am looking for plans and drawings to built
    a step/direction to +/- 10v (analog) converter for controling
    my 3phase spindle drive(VFD) with MACH3.
    I was told that SKYKO had this but not any more.
    So im thinking to build me one.
    Can someone help me with this.
    Thank you.
    KRUMMI
    24221
    I believe you want PWM to ±10vdc, last time I checked the spindle was controlled this way.
    Al.
    Albert E.
    Mar 2004
    1306
    At $38, is it worth doing it yourself?
    http://homanndesigns.com/store/index...c602191e6fa87c
    Regards,
    Mark
    Jul 2007
    887
    The Skyko product you mentioned was for controling analog servo-amps with encoder feedback back to the Skyko card, ie for closed loop servomotion.
    Mach3 can control a spindle either thru step and direction or low frequency PWM. The LM2907 is a frequency to voltage converter chip that can be used to convert the step-pulses to an analog voltage. I'm attaching a schematic of how I did mine a couple of years ago.
    Attached Files Attached Files
    Jan 2009
    57
    British option
    I have used boards from this site with good results. This controller includes a relay for reversing direction.
    http://diycnc.co.uk/html/spindle_2.html
    May 2007
    380
    www.cnc4pc.com may have what you are looking for.
    John
    Jul 2005
    2415
    Quote Originally Posted by krummigudna View Post
    Hello everyone.
    Thank you.
    KRUMMI
    You migth want to check your VFD specs again. Most use 0 to +10VDC (unipolar) for 0 to max RPM. I have not seen one (VFD) that uses negative voltage for speed control. + & - 10 are used in older servo drives to do both speed (velocity) and direction with one signal. The Skyko was made for that usage but the demand is low for analog only servo drives running from S & D. There are alot of spindle speed 0-10VDC solutions. Try to determine what you need and if it needs to be isolated. Some VFD's internal electronics are not isolated from the AC lines and can really mess up anything connected back to the PC logic side. Lots of noise in VFD's too...another good reason for isolation.
    TOM Caudle
    www.CandCNC.com
    Jun 2007
    15
    Hello everyone.
    Tom, you are right this is controled like you pointed out.
    There is a diffrent signal for changeing direction.
    Just a shortcircuit in my head.
    Thank you for your time and effort to help me.
    Krummi
    Jun 2007
    15
    Al.
    You are right Al it can be controlled this way (and maybe it is a better way).
    According to the MACH 3 turn manual it can also be controled with step/direction.
    I have not tried it so i dont know if it works.
    Do you think PWM is a better way ?
    Krummi
    Jun 2007
    15
    Quote Originally Posted by jjobezo View Post
    Good tip jjobezo
    but i am not sure the British want anything to do with ICELANDERS right now
    ..............hahahahaha (nuts)
    Krummi
    Jun 2007
    15
    Quote Originally Posted by H.O View Post
    Your answer and drawings were very helpful H.O
    Krummi
    Jun 2007
    15
    Quote Originally Posted by RotarySMP View Post
    Good point, but im the (built everything myself type)
    ......hahahahaha....
    Krummi
    Jun 2007
    15
    Quote Originally Posted by johnmac View Post
    John
    Good tip John.
    Krummi.
  1. PWM&direction into voltage converter
    By visky in forum Want To Buy...Need help!
    Last Post: 04-05-2009, 05:47 PM
  2. Step and Direction to Analog
    By gdb in forum CNC Machine Related Electronics
    Last Post: 11-15-2007, 05:19 AM
  3. Convert +- Analog to Step & Direction ???
    By Argofanatic in forum Servo Motors / Drives
    Last Post: 01-20-2007, 10:47 PM
  4. Pixie Step/Dir to Analog Servo Controllers
    By KTP in forum News Announcements
    Last Post: 03-06-2006, 05:12 PM
  5. Step/Dir to Analog converter?
    By DennisCNC in forum Servo Motors / Drives
    Last Post: 12-19-2005, 12:05 PM
