586,071 active members*
4,073 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Amada Press Brake Controller problem
    Sep 2009
    30
    Exclamation Amada Press Brake Controller problem
    Hi, I just bought a rebuilded Amada FBD-8025 Brake Press, it has 8-axis movement with a windows 3.11 based controller and touchscreen, after a few minutes of working fine, the touchscreen goes off, and I have to reset the whole machine and start over again, its arround ten minutes that the screen goes off no matter whatever you're doing, My guess is the power supply for the PC is not working correctly, I'm trying a few things today.
    Any ideas will be greatly appreciated.
    Best Regards
    24221
    Is it just the screen goes blank? If you know the position of a function, does the touch screen still activate it?
    If so, if it is LCD screen it could be the backlight inverter failing, you can tell this by looking at the rear of the LCD, the florescent light should be lit.
    replacement lamps and invertors are available from DigiKey.
    Al.
    Albert E.
    Sep 2009
    30
    You were right
    Hi, you were right, the backlight of the screen is failing, I'll bring a technician to see if he can fix it or replace it.
    Thanks a lot.
    24221
    You can actually measure the output of the inverter, it is 800 to 1000vdc.
    Usually if the screen goes blank suddenly it is the inverter, if it fades out, it is the tube.
    Al.
    Albert E.
    MachineMfg Guest
    Re: Amada Press Brake Controller problem
    You can refer to this article writing about press brake troubleshooting.
  1. Amada Press Brake
    By Footballwr46 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2018, 03:29 AM
  2. AFM Press Brake Controller
    By toolchip1 in forum SIEMENS -> GENERAL
    Last Post: 02-19-2013, 05:56 AM
  3. Amada Pega 344 Punch Press Clutch/Brake Assy Breakdown
    By tony@sm-w in forum Community Club House
    Last Post: 03-15-2012, 12:16 AM
  4. Amada PRESS BRAKE HFT 220-3
    By M7MED in forum Bending, Forging, Extrusion...
    Last Post: 12-30-2011, 03:04 AM
  5. Amada brake press controller nc9 r
    By maplesiport in forum Controller & Computer Solutions
    Last Post: 07-15-2010, 11:32 PM
