586,076 active members*
4,023 visitors online*
    Aug 2006
    36
    Unhappy FANUC 0T FEMCO DURGA 25E
    WE HAVE A ISSUE WITH TWIN TOOL TURRET, IT FUNCTION RIGHT ON MANUAL MODE BUT WHEN THE PROGRAM IS RUNING THE TOOL-CHANGE PROCEDURE DON`T EXECUTE
    CAN YOU HELP ME...
    THANKS.
    May 2013
    The Durga needs to have the turret in the index position of one turret in order to change the other turret under program control.
    I think the index positions are position #1 for the front turret and position #21 for the back turret.
    We have a Femco Durga 25 at school and leave tool positions #1 and #21 empty. We start a with #1 and #21 in position.
    For example, if you have been using tool #4 and you want to use tool #25, you first have to change to tool #1 (put the front turret in the index position) and then change to tool #25.
    If you want to change from tool #25 to tool #6, you first have to change to tool #21 (the back turret index position) and then change to tool #6.
    Good Luck.
  1. Femco Durga 25-E
    By Billet Sean in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2020, 02:30 PM
  2. Femco Durga 25-E Service Tech
    Last Post: 10-17-2010, 07:57 PM
  3. Femco Durga-25E Tool Change Issue
    By GM81 in forum Uncategorised MetalWorking Machines
    Last Post: 01-22-2010, 12:29 PM
  4. FEMCO DURGA 25E
    By destinationmx in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2008, 01:00 AM
