Guys
I need a little help with some troubleshooting..Here is what I was doing and what happened..
I was machining aluminum and using the midi to control the machine. The spindle was set with the S word to 4000, I made a couple passes and finished the Op and ended with M5 and M8. I moved the axises with the jog shuttle. I changed the tool to a slitting saw and set the S word to 900. I then typed in M3 and hit enter, when I did the GFI on the 110 outlet tripped.
I unplugged the machine and reset the GFI and plugged it back in, it tripped again. Next I unplugged all of the 110 devices including the PC from the back of the machine. and plugged it in, It tripped yet again.
So at this point I'm up for Ideas. I was thinking about disconnecting wires until it stopped tripping and go from there.
I wanted to see if anyone has experienced this problem in the past before I start that line of troubleshooting.. My machine is the older version with an analog drive.
Any thoughts or ideas would be appreciated! Thanks!!
Larry O
