586,494 active members*
2,348 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > KiaTurn15 Yasnac LX3 help
    Jan 2004
    137
    I have this older KiaTurn 15 with a Yasnac LX3. After numerous problems with the control, hopefully it is ready for use.
    Below is my coding and after it clears the offset "T0300" and goes to the new tool "T0202". It takes off in the wrong direction. I am unsure of the problem at this point.
    If anyone is familiar with this control, could you take a look at the following code and tell me where my feeble brain is messed up? Am I mis-using the G50 on this machine?
    I am open to suggestions...
    O0003
    G20G40
    G50 X7.136 Z8.90
    G0 S700 M03 T0303
    M08
    G00 X1.25 Z0.06
    N80 G71 P90 Q260 U0.002 W0.002 D0.025 F0.008 S700
    N90 G01 X1.164 Z0.06 F0.008
    N100 G01 X1.164 Z0.
    N110 G01 X1.164 Z-0.02
    N120 G03 X1.1529 Z-0.038 I-0.032 K0.
    N130 G02 X1.1529 Z-0.132 I0.0692 K-0.047
    N140 G03 X1.1529 Z-0.168 I-0.0265 K-0.018
    N150 G02 X1.1529 Z-0.262 I0.0692 K-0.047
    N160 G03 X1.1529 Z-0.298 I-0.0265 K-0.018
    N170 G02 X1.1529 Z-0.392 I0.0692 K-0.047
    N180 G03 X1.1529 Z-0.428 I-0.0265 K-0.018
    N190 G02 X1.1529 Z-0.522 I0.0692 K-0.047
    N200 G03 X1.1529 Z-0.558 I-0.0265 K-0.018
    N210 G02 X1.1529 Z-0.652 I0.0692 K-0.047
    N220 G03 X1.1529 Z-0.688 I-0.0265 K-0.018
    N230 G02 X1.1529 Z-0.782 I0.0692 K-0.047
    N240 G03 X1.164 Z-0.8 I-0.0265 K-0.018
    N250 G01 X1.164 Z-0.91
    N260 G01 X1.25 Z-0.91
    M09
    G0 X7.136 Z8.90
    T0300
    G20G40
    G50 X8.654 Z7.4283
    G0 S800 M03 T0202
    M08
    G00 X0. Z0.05
    G01 X0. Z-0.05 F0.004
    G00 X0. Z0.05
    M09
    G0 X8.654 Z7.4283
    T0200
    G20G40
    G50 X8.654 Z2.2283
    G0 S1200 M03 T0606
    M08
    G00 X0. Z0.05
    G01 Z-0.5 F0.004
    G0 Z0.2
    Z-0.45
    G01 X0. Z-1.
    G00 X0. Z0.05
    M09
    G0 X8.654 Z2.2283
    T0600
    G20G40
    G50 X8.654 Z7.154
    G0 S600 M03 T0404
    M08
    G00 X0. Z0.05
    G01 X0. Z-0.75 F0.004
    G00 X0. Z0.05
    M09
    G0 X8.654 Z7.154
    T0400
    G20G40
    G50 X9.543 Z9.2
    G0 S600 M03 T0101
    M08
    G00 X1.3 Z-0.83
    G01 X0.04 F0.002
    G00 X1.3
    M09
    G0 X9.543 Z9.2
    T0100
    M05
    M30
    "Plan your work; Work your plan"
    Jan 2004
    137
    My issue is resolved, basic idea is below
    G0 T0303
    G50 T5303 Sets offset out of a table
    Work cutting moves here
    T0300 clears offset
    G0 X0.0 Z0.0 takes turret home
    May 2009
    104
    I run a Kiaturn21 with an old Yasnac control.
    Tool offsets are very basic on these controls.
    T100 will call tool 1 and offset 1.
    G0G28U0W0 will return tool to home.
    T200 will call tool 2 and offset 2.
    GOG28U0W0 will return home.
    Also when using G71 if your start point in X doesn't match your last X value in the canned cycle code you will get an alarm. This drove me nuts until I figured it out.
    Jan 2004
    137
    I will keep that in mind.
  1. Yasnac mx1 vs. mx5
    By Brian FRF in forum Uncategorised MetalWorking Machines
    Last Post: 06-10-2009, 05:32 AM
  2. Yasnac help
    By cncwhiz in forum Uncategorised MetalWorking Machines
    Last Post: 03-26-2009, 12:48 AM
  3. Yasnac LX3
    By inthedark in forum MetalWork Discussion
    Last Post: 08-07-2008, 11:03 AM
  4. yasnac J 100 M
    By Furlan in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 11-17-2007, 04:55 PM
  5. Yasnac I80
    By Gitanes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2005, 06:00 AM
