Can someone please explain this to me in simple terms. Is this the same as G5.1 Q1 or similar? What is the difference?
On my Duravertical, G332 sets the cutting mode. R1. (speed priority) - R4. (better accuracy)
For example:
G332 R1. (SET CUTTING MODE)
G05.1Q1 (ACTIVATE AICC)
I had Mori tune the settings for R1. to get the fastest and smoothest motion while roughing at high feed rates.
I usually use R2. for finishing.
Surprised at how fast and smooth the machine is with AICC. It's only a 0iMC after all.
So you use them together? This is a little confusing to me as it was explained to me that all I would need to use is the G332 and that it "replaces" the G05.1Q1.
I am trying to create a post and am trying to get the correct information before getting too far.
Thanks for the reply!
Yes, they are used together. Once the cutting mode is set you don't have to write it in unless you want to change it again.
So, if for example you wanted to use R3. on all tools, just write in in for the first then you only need G05.1 for the rest. From memory the default is R3. if you don't set a cutting mode yourself.
Have you got manuals for the machine? it should all be there. Still doesn't make much sense initially though......
For my post, I have it writing in G332 R3. every time. I just manually change it to suit roughing or finishing. I guess I could have the post automatically write in the appropriate setting......
I dont have the manuals yet, and in fact I do not even have the machine yet. I am trying to prepare for it.
I have been talking to the applications guy and he gave me a post for the machine but it is mucked up. It doesnt post B axis rotations and it is set up to post for HPCC rather than AICC. We purchased the machine with level 2 AICC (hope that I am not lying here) so the codes that he is telling me will work with our machine I dont think are correct.
I emailed him today and he is still telling me that I use G332 R1-4 in conjunction with G5 P1000, which if I am not mistaken, is HPCC.
I think that one of us are confused. I better make that both of us.
I have managed to create a post that outputs the high speed machining code but i need confirmation.
After what you have said here, the G332 is not used until the High speed machining code is fired? is that correct?
Thanks! You are definitely helping.
Well firstly, remember my machine has the 0i control, so it may be different. I did purchase the AICC option though, but it would be more basic than what is available for the NH.
The manual says that G332 is used to set the cutting mode when using "AI look ahead/AI contour control" So the answer to your question is Yes, G332 is only used once hsm is fired.
Other ways to set the cutting mode are the "cutting mode selection" screen or setting the cutting mode with a MAPPS parameter.
To me, it seems best to always use G332 so you can change the cutting mode to suit the operation you are doing. That works well for me, and the difference is definately noticeable.
My machine doesn't use the G5 P1000, etc. Not sure if that is for HPCC or AI nano or what.
Here's some pics. One showing some code where I have used AICC, and the other showing the "status" notice the "R3." The blank box flashes "AICC" when activated.
Hello,
I am haapy to you all thru this CNC ZONE .Please keep in touch.
Jabu
yea you guys basically nailed it on the head.
what G332 does is give priority to speed or accuracy depening on the R1-4 selection. R1 gives you move jarring accel/decel in corners and such with a speed priority rather than accuracy so you have to be careful when using R1 because you might overshoot your dimensions when you use R3 or R4 for finish cuts (which accel/decel's much slower/smoother).
Oops, never mind.
It seems there is no way to delete a post.
Hello i have a question...
i have mori seiki sh403 mill with sh501 control i belive thats fanuc i18
and i have the same problem with h/s cutting
but G332 and G5 dont work on my machine....
G49
G322 R3 alarm come out umber not found
G5, G05.1 inproper G code....
can some one help?? (flame2)
