586,116 active members*
3,440 visitors online*
Results 1 to 7 of 7
    Apr 2007
    5
    ball screws for Sherline lathe
    I have a Sherline lathe that I am considering converting to CNC. What I am considering is converting the stock leadscrews over to ballscrews. Has anyone done this or is this even something that is worth taking the?
    Melvin
    Jan 2010
    Cool ball screws for sherlines?
    I am looking for ballscrews for my sherline too. please let me know if you find any and I'll do the same for you. If I can't find any I am gong to buy the right size ballscrew and tun the end down to the proper dimension on a cylindrical grinder. so if you want some custom ones I'm looking into it.
    Mar 2004
    439
    You could check out Misumi - they offer ballscrews in diameters as small as 8mm OD.
    http://www.misumi-ec.com/usa/eusaen/..._20090300.html
    Keith
    Mar 2006
    474
    There isn't enough room for a ballnut inside the Sherline mill saddle, at least not for an 8mm ballscrew.You could possibly mount it to the back of the saddle for the Y axis, but for X, anything larger than .375" would rub the underside of the table.
    I'm hoping to one day find a 1/4" ballscrew, or convert to Acme threads, but for now, the stock leadscrews work fine for me.
    http://www.youtube.com/user/vlmarshall
    Dec 2007
    17
    Have you looked at Roton? We buy ACME lead screws from them and I know they have ball screws/ball nuts. Check this link:
    http://www.roton.com/QS_Ball.aspx?line=Quick
    They make some pretty good products.
    Mike
    Mar 2006
    474
    I just realized that my above post is a bit absent-minded, and talks about the Sherline MILL, not lathe. Oops. There's a LOT more room on the lathe, and I'd love to convert mine, as well.
    Quote Originally Posted by eljainc View Post
    Mike
    Nice link, Mike. That's the first 1/4" ballscrew I've seen.
    Mar 2004
    439
    Mike-
    Notice that the 1/4" ballscrew is "freewheeling":
    http://www.roton.com/freewheeling-ba...e=Freewheeling
    There are no internal threads on the inside of the ballnut, and this should not be used on machines that use the rotation of the screw for feedback.
    Here is a translated german website (Steinmeyer) who makes a 3mm OD ballscrew:
    http://translate.google.com/translat...de&sl=de&tl=en
    Keith
  1. Ball screws
    By htto in forum Benchtop Machines
    Last Post: 07-21-2007, 01:30 PM
  2. ball screws
    By skeezy in forum Linear and Rotary Motion
    Last Post: 05-15-2007, 07:45 PM
  3. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
  4. Which Ball Screws to use?
    By Willyb in forum Linear and Rotary Motion
    Last Post: 01-20-2005, 03:49 AM
  5. ball screws anyone!
    By turmite in forum DIY CNC Router Table Machines
    Last Post: 01-14-2004, 02:25 AM
