Hello. Once again I have to move my R2E4. Unfortunately it has to pass under some low beams which the head will not clear. Last time I just removed the head which was a serious pain given the lack of ceiling clearance. Basically I ended up just manhandling it on there.
So my question is... will the head bolt on at a 90degree angle from upright? It is a rigid ram. Ie if I unbolt it and rotate 90 will it bolt down that way? It looks like the bolt pattern is near square but it is hard to eyeball. If I could do this it would save me a lot of trouble.
If anyone knows it would be greatly appreciated! Thanks in advance!
James
