586,119 active members*
3,778 visitors online*
    May 2008
    8
    DIY 3 axis CNC Milling Machine.
    Hi Folks!
    I have done about 1 or 2 months of research into this subject.
    It feels like I can continue this reasearch for a few more months
    But I have to get started with buying the parts.
    Someone told me that if I buy a plan that would make my job easier.
    First let me tell you the kind of machine I would like to build
    This is a model that I can picture myself making
    The mill with the blue frame
    This has 4 stepper motors
    I would like to concentrate on that model
    What do you folks think
    http://www.pdjinc.com/pilot%20information.html
    Here is another picture
    Steel / 8020 Hybrid Version
    http://www.pdjinc.com/pilot%20rails.html
    If anyone can help that would be nice
    I need to know all the details like what kind of stepper motors to buy ,lead screw
    the driver and so on.
    or
    I need is a plan to follow maybe I can buy a plan
    I should say that I would like to ba able to cut aluminum for molds for
    injection casting with this machine.
    Here is fantastic site with lots of pictures
    I dont understand the language
    maybe I can go to google translate
    Do you think I can choose a picture of a model that I think I would be able to make and start this project
    I will be buying a torch but for now I can work with steel frames
    I will buy a dril and attach everything with a bolt and a nut
    Will the bolt and the nut idea be strong enough
    would i have to add glue or solder to the nut and the bolt
    http://www.hobbycnc.hu/English.htm
    I want the cutting area to be about 4 feet x 3 feet.
    I have a few design ideas I have seen on few web sites
    They have details here is one of them
    http://buildyourcnc.com/default.aspx
    As a final note I would like to know how to get started
    Either
    1) I buy a plan ( I need to know from where)
    or
    2) Someone posts the pla here
    May 2008
    8
    Hi Folks
    I think I would have to build 2 machines
    1) larger machine like I am talking about here in this thread
    2) A machine for cutting aluminum to make dies will have to be smaller and stronger.
    If anyone has links to plans I would like to have them
    Feb 2008
    521
    To my mind what you've identified are CNC Routers not milling machines.
    A router may be able to cut thin Ali sheet but may struggle with a full on 3D profile for a mold pattern? Routers are good machines as long as you understand their limitations - materials and capacities.
    May 2008
    8
    Hi kawazuki
    Thanks for your reply
    I guess I would like to have 2 machines
    1 router
    the other one a milling machine.
    The milling machine would have to have powerful motor so then the structure would have to be more sturdy. This would have to be smaller because the molds I want to make will be for jewelry.
    The router can be a bit larger.
    There are many sites with people posting pictues of their cnc project that I can follow
    Should I do that or try to buy a plan.
  1. My 3-axis foam milling machine
    By Rhino3Master in forum CNC Wire Foam Cutter Machines
    Last Post: 11-15-2009, 05:04 PM
  2. Advantage of a 3 axis CNC Milling machine
    By george_kj in forum Uncategorised MetalWorking Machines
    Last Post: 04-28-2008, 10:46 AM
  3. How many axis to DRO on a Milling machine?
    By hotponyshoes in forum Uncategorised MetalWorking Machines
    Last Post: 05-15-2007, 08:16 AM
  4. 5 axis milling machine
    By toneV8 in forum Uncategorised MetalWorking Machines
    Last Post: 11-29-2005, 11:11 AM
  5. Replies: 3
    Last Post: 05-18-2005, 05:15 PM
