From the "Jogging bug..." thread:
Are you using lead in or out on any of the ops where you get this error? I recall getting the same thing before and have a nagging memory that it was related to the lead in parameters on at least one occasion. In other cases I think it may have been related to the radius on the corners of a rectangular pocket and that increasing the design corner radius to something a little over the size of the cutter resolved it.P.S. And at the risk of a hijack, I'll answer MichaelHenry from several days ago: When I am milling very small details, SprutCAM will create a command for an arc, but will put zero for the radius. Mach will load the program and display it just fine, but will stop on that block and croak when I run it. The fix (for me) is to edit the program and replace all occurrences of zero radius with a small number (like 0.0001). The saddest part is that I usually find out after the part runs for a while, so I usually start from that line after I fix the problem. It's always a nail biter to restart like that, especially with very small tooling.
For example if using a 1/4" end mill to mill out a 2" x 4" pocket, I'd specify 0.251" radius on the corners of the pocket in the Alibre design.
Of course I could be mis-remembering all or any of the above.
I'm absolutely positive that it annoyed the heck out of me every time it happened.
Mike
