586,076 active members*
3,757 visitors online*
Thread: Gear Clock
Results 1 to 6 of 6
    Dec 2008
    33
    Gear Clock
    Ever since I setup the CNC machine and built the controller housing I have been playing around with various ideas. Wooden gear projects have been around for a long time, and lots of people have made conventional gear clocks. I wanted to do something a bit different. This project combines some electronics and lots of wood.
    Full project details can be found here:
    http://alan-parekh.com/projects/gear-clock/
    [ame="http://www.youtube.com/watch?v=zkLIKfdYW3I"]YouTube - Gear Clock[/ame]
    Many articles about hacking gadgets. Examples of extreme technology. DIY projects describing how to build electronic projects. http://hackedgadgets.com
    Aug 2003
    73
    I like it! Very cool! Is it your own design? I bet corian would make some nice gears.
    Jeff T.
    http://www.3dcarvestudio.com
    Dec 2008
    33
    Quote Originally Posted by jeffery71 View Post
    Jeff T.
    Hi Jeff,
    Corian would work great but it would much more expensive than the MDF that I made it with. Yes I designed the clock.
    Dec 2009
    66
    cool design. though im still uncertain at how to tell wht the time is
    Dec 2008
    33
    Hi HellPhish,
    Thanks for having a look. You just need to look at the top of the two gears. When the 12 and 0 are on top it is 12:00. It the first one is half way between 1 and 2 and the second one is at 30 it is 1:30.
    Dec 2008
    33
    Gear Clock Kit now available
    Hey Guys,
    The gear clock kit is now available and there is an electronic only option so that you can make the gears yourself using your own CNC machine.
    Have a look at the Gear Clock Kit options here:
    http://alan-parekh.vstore.ca/index.php/cPath/1_20
    And get the DFX and G-Code files for all of the gears here:
    http://alan-parekh.com/kits/gear-clock-kit
    In the manual the full schematic is provided and the PIC microcontroller firmware is also provided so if you are feeling adventurous you could build the entire thing from scratch.
    Regards,
    Alan Parekh
  1. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  2. another clock
    By balsaman in forum WoodWorking Topics
    Last Post: 05-14-2009, 02:17 AM
  3. So I made a clock too
    By gianluca70 in forum WoodWorking Topics
    Last Post: 12-18-2008, 02:36 PM
  4. Clock interupt or something?
    By thedoctor in forum Controller & Computer Solutions
    Last Post: 07-24-2008, 11:41 PM
  5. A cnc clock
    Last Post: 01-26-2008, 08:15 PM
