586,096 active members*
3,779 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > 0 ~ 10V analog adjust speed in CNC machine
    Smile 0 ~ 10V analog adjust speed in CNC machine
    DC Brushless Motor Drive Controller Unit(CNC Machine, Mechanical Equipment)
    Main function:
    ◆ Start, Stop, accelerate or decelerating, forward and reverse function
    ◆ A LCD displays real-time speed, the current state, protection
    ◆ A flow, over-voltage, overload, voltage protection function
    ◆ Motor temperature detection
    ◆ 0-10V analog speed control◆ Provide the user interface should choose function. Panel
    ◆Should provide 485 interface and TTL interface, which can be conveniently and communication
    ◆With a sudden stop machine, electric switch, protective mask open doors limit protection
    ◆Speed 400~6000rpm
    ◆Drivers can access AC110V/220V two kinds of voltage, in the same drive can be switched
    CN17—0V ~ 10V analog speed control port when the user interface when selecting a foreign force, in this port by adding the signal voltage of 0V to 10V can realize a linear motor speed control function.
    www.sangmutan.com
    [email protected]
    Attached Thumbnails Attached Thumbnails 0V-min.jpg   5V-middle.jpg   10V-max.jpg   05.jpg
    Attached Files Attached Files
    Aug 2009
    13
    Quote Originally Posted by Kung fu panda View Post
    Main function:
    ◆Speed 400~6000rpm
    www.sangmutan.com
    [email protected]
    how much 1.1kw 6000rpm motor &controller ?
  1. analog of surface speed
    By Zig in forum LinuxCNC (formerly EMC2)
    Last Post: 09-12-2009, 04:50 AM
  2. Feed and speed to machine HSS
    By zaebis in forum MetalWork Discussion
    Last Post: 08-30-2009, 01:35 AM
  3. how to adjust speed of the transmission
    By scampo77 in forum Benchtop Machines
    Last Post: 02-08-2009, 05:27 AM
  4. analog input VFD speed Hitachi SJ100
    By Karl_T in forum Phase Converters
    Last Post: 11-22-2008, 10:09 PM
  5. Speed of CNC machine
    By tivoidethuong in forum Mechanical Calculations/Engineering Design
    Last Post: 04-25-2006, 11:02 AM
