586,275 active members*
3,285 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > Graphite permanent die casting aluminum?
    Aug 2005
    828
    Any one have experience with making two part graphite dies for casting aluminum parts?
    It will be a simple part, here are pictures of a sand cast one i did.
    Dennis
    T3sl4 Guest
    Should work fine. I don't have any experience myself, but I know a guy who has a little:
    http://theodoregray.com/periodictabl...7.html#sample9
    Graphite is flexible, so extraction should be easy, and it's basically self-lubricating, but it will wear quickly. Should still be possible to get... ehhh... 100 castings from a set easily? Gee, that doesn't sound very economical, sand castings are fine up to the thousands as I hear it.
    Tim
    Aug 2005
    828
    Thanks for the link. I just want to have a nice finish on the part if possible. And seems to me it will be less involving like sand. I have two full size VMC's so making the graphite dies is no problem just wanted to consult with some one on the tech details of making dies.
    Dennis
  1. Several DIY casting questions... Lost Wax & Aluminum?
    By Sporqster in forum Casting Metals
    Last Post: 10-01-2007, 04:29 AM
  2. What foam for aluminum casting?
    By biomed_eng in forum Casting Metals
    Last Post: 03-13-2007, 03:30 PM
  3. Question on permanent molds for aluminum
    By CPS in forum Casting Metals
    Last Post: 07-29-2006, 12:35 PM
  4. aluminum casting advice needed
    By carbidecraters in forum Casting Metals
    Last Post: 07-05-2005, 04:04 AM
  5. A guide to permanent mold casting.
    By Splint in forum Casting Metals
    Last Post: 11-29-2004, 12:36 AM
