586,104 active members*
3,262 visitors online*
Results 1 to 18 of 18
    Jul 2003
    1754
    New GUI for touchscreen/no keyboard.
    (and mouseless) One of the emc2 developers got a Mori Seiki JR with a dead control and converted it to emc. He wanted to make a clean keyboardless interface. This is in the development version of emc2. You can see the before here..
    http://geektrap.com/bill/01248711886
    after
    http://timeguy.com/cradek-files/emc/jr.jpg
    It isn't 100% yet - in the next post I will have the design notes. It does require some hard controls..
    ( http://git.linuxcnc.org/gitweb?p=emc...2c895a;hb=HEAD )
    Pretty cool!!
    sam
    Attached Thumbnails Attached Thumbnails startup.jpg   mdi.jpg   manual.jpg   auto.jpg
    Jul 2003
    1754
    http://git.linuxcnc.org/gitweb?p=emc....notes;hb=HEAD
    The design of "touchy"[1] is as follows:
    No keyboard is required.
    No mouse is required. It is meant to be used with a touch screen.
    Configurability of font sizes makes it work with any screen
    resolution.
    Some hard controls are required. The absolute minimum set of
    controls is:
    * A momentary abort button, connected to the hal pin touchy.abort
    * A momentary cycle start button, connected to touchy.cycle-start
    * A wheel/mpg, connected to touchy.wheel-counts
    * A single block toggle switch, connected to touchy.single-block
    * Of course, a real estop button hardwired in the estop chain
    as usual (not strictly related to touchy)
    Additionally, there are some optional controls:
    * If continuous jog is wanted: Three center-off bidirectional
    momentary toggles (or worse, six buttons), hooked to
    touchy.jog.continuous.x.negative, ....x.positive,
    ... y ...,
    ... z ...
    * If a quill up button is wanted (to jog Z to the top of travel at
    top speed), a momentary button connected to touchy.quill-up
    There is currently one optional indicator output:
    * touchy.jog.active can be connected to a panel lamp to show when
    the panel jogging controls are live
    Touchy has several output pins that are meant to be connected to
    the motion controller to control wheel jogging. They are:
    touchy.jog.wheel.increment => axis.N.jog-scale (for all relevant N)
    touchy.jog.wheel.x => axis.0.jog-enable
    ... y ... => ... 1 ...,
    ... z ...
    Also be sure to connect the wheel/mpg to axis.N.jog-counts as well as
    to touchy.wheel-counts. If you use ilowpass to smooth wheel jogging,
    be sure to smooth only axis.N.jog-counts and not touchy.wheel-counts.
    Touchy requires you to write a file named "touchy.hal" to make
    these connections. Touchy executes the hal commands in this file
    after it has made its pins available for connection.
    These things are not done, and should be done:
    * Configurable axes for 5 axis machines, etc.
    * Lathe support which shows radius/diameter instead of X
    * i18n
    These things are not done, and may or may not ever be done:
    * direct viewing and editing of tool table.
    I currently use a network connection for this, just like I use
    network to edit/replace the gcode programs. G10 L1/L10 is good
    enough for the normal tasks.
    * Calculation and display of the extents of the loaded program
    This requires interpreting the entire program, and is a bit hard
    to get right because of tool lengths and other considerations
    like probing.
    These things will never be done, don't ask:
    * Add onscreen controls for jogging and cycle start, etc, so
    touchy can be used without real controls on a real panel
    The reason for this is the unreliability of touch screens and
    the safety that comes from having actual buttons/switches/wheel
    to do dangerous and critical operations such as executing gcode
    or jogging. Even with MDI you must use the real button, after
    confirming the command displayed onscreen is what you want.
    This is a feature.
    (It is possible that homing and spindle fwd/rev should also
    require a press of the cycle start button for safety's sake.
    They currently do not.)
    I have seen two controls that attempt to allow you to jog using
    a mouse or touchscreen. On one you drag your finger/pointer in
    a circle. On the other, you drag it from side to side. These
    work very badly and touchy will not have a scheme like this.
    * adding a full onscreen keyboard for any reason
    These suck.
    [1] Like "git", "touchy" is named after its author.
    Nov 2009
    88
    Thanks for posting this! I'm in the process of setting up a small mill conversion with a touchscreen and this is exactly what I was looking for.
    Cheers,
    - Dean
    May 2006
    122
    This is completely awesome. Thanks for posting.
    I would very much like to refurbish a dead 3 axis knee mill with EMC since I use it on my gantry router and love it, but would really prefer to use the stock touchscreen location.
    Oct 2009
    12
    thats for posting this, i too am going to try this out once i get everything running good.
    Apr 2009
    95
    I loaded the Touchy interface. I like the way it works. One addition would be visual feedback on the handwheel buttons Change color on selection so you can see where you are at. Just the kind interface I needed.
    Jim
    11
    I am a little new to EMC2 but not to CNC. I would like to get the Touchy interface working but I am unsure about how and where to install it. Any help would be greatly appreciated.
    John Guenther
    'Ye Olde Pen Maker'
    Sterling, Virignia
    John Guenther
    'Ye Olde Pen Maker'
    Sterling, Virginia
    Apr 2006
    76
    This is interesting.
    How does it work with no keyboard if there are only "G","M",and "S" letters available? You could not even do a tool change like this.
    Just off the top of my head you need D,F,H,Q,I,J,K,X,Y,Z.....
    Jul 2003
    1754
    I didn't get a screen shot of that.. but as you start typing say G2.. Then it fills out the manual screen with x y i j lets say (depending on the plane selected) It is very intuitive.
    this is a quote from someone that runs large machining centers on emc2.
    Gentlemen,
    Yes, Cradek has dabbled with touchy. I am using touchy on the G&L. I have
    run Cradek's Mori Seiki Jr with touchy. My assessment is touchy is ready for
    prime time. It seems complete. Touchy needs people to use it and give their
    evaluations and suggestions.
    I will change all my machines to touchy. Touchy is well thought out. Kudos
    to Cradek for 'dabbling' with it.
    thanks
    Stuart
    sam
    11
    Hello, I am trying to get touchy to work on my system. I started trying to get it to work on 2.3.5 with no joy. It was suggested to me on the emc users list over on source forge that I should upgrade to the 2.4 Pre release which I have done and I still can't get it to come up. I really like what I have seen so far and would really like to try it out.
    Any assistance will be greatly appreciated.
    John Guenther
    'Ye Olde Pen Maker'
    Sterling, Virginia
    Nov 2009
    88
    Quote Originally Posted by j.guenther View Post
    Have you had any luck bringing Touchy up?
    I will be trying over the weekend, but I thought I'd bump this thread incase anybody can provide guidance getting it going easily.
    [EDIT]
    I went looking on the EMC2 forum and found a link to this page.
    It looks like EMC2 2.4 may be released in just a few weeks,
    so I think I'll wait instead of trying to cobble it together myself.
    [/EDIT]
    Cheers,
    - Dean
    11
    Yes. I got Touchy up and running. I upgraded to 2.4.0~pre and after correcting some errors caused by my attempts at getting it running with 2.3.5 it came up just fine. I looks real nice, seems to work well on my 800x600 display. I am currently working on a very basic pendant for the required 'hard' controls. As soos as that is done I will try using it in the shop.
    John Guenther
    'Ye Olde Pen Maker'
    Sterling, Virginia
    Mar 2009
    I have interest in the touchy interface and EMC on a slightly larger Mori MV-55 with 30 station ATC. Have you extended the interface in any way since 2009?
    Chris
    May 2010
    hello
    I am a new user emc2
    I am looking to set up ll'interface touchy but I can not make it work
    one of you could do me a tutorial to make it work
    thank you in advance
    Nov 2005
    496
    Please be specific about what troubles your having.
    will it not load? can you not make it operate ? Is it a touch screen problem?
    Can you post your EMC config files? How did you make the config files.
    Chris M
    May 2010
    hello chris
    I just wanted to know how it was to configure the file for HAL touchy
    because there are four connection has to do with touchy is that's what I do not know how
    So if I had a sample that HAL would be easier for me to understand
    Nov 2005
    496
    Here is a sample I found (I haven't used it )
    Of course you would need to change the hm2_ commands to what ever I/O you are using.
    loadrt ilowpass
    loadrt scale count=1
    setp ilowpass.0.scale 1000
    setp ilowpass.0.gain .02
    addf ilowpass.0 servo-thread
    setp scale.0.gain .00025
    addf scale.0 servo-thread
    net JogIncr touchy.jog.wheel.increment => scale.0.in
    net JogIncrScaled scale.0.out => axis.0.jog-scale axis.1.jog-scale axis.2.jog-scale
    net JogX touchy.jog.wheel.x => axis.0.jog-enable
    net JogY touchy.jog.wheel.y => axis.1.jog-enable
    net JogZ touchy.jog.wheel.z => axis.2.jog-enable
    net WheelCounts hm2_5i20.0.encoder.00.count => ilowpass.0.in touchy.wheel-counts
    net JogCountsLowpass ilowpass.0.out => axis.0.jog-counts axis.1.jog-counts axis.2.jog-counts
    net JogXPos hm2_5i20.0.gpio.020.in_not => touchy.jog.continuous.x.positive
    net JogXNeg hm2_5i20.0.gpio.019.in_not => touchy.jog.continuous.x.negative
    net JogYPos hm2_5i20.0.gpio.018.in_not => touchy.jog.continuous.y.positive
    net JogYNeg hm2_5i20.0.gpio.017.in_not => touchy.jog.continuous.y.negative
    net JogZPos hm2_5i20.0.gpio.016.in_not => touchy.jog.continuous.z.positive
    net JogZNeg hm2_5i20.0.gpio.015.in_not => touchy.jog.continuous.z.negative
    net QuillUp hm2_5i20.0.gpio.013.in_not => touchy.quill-up
    net CycleStart hm2_5i20.0.gpio.023.in_not => touchy.cycle-start
    net Abort hm2_5i20.0.gpio.022.in_not => touchy.abort
    net SingleBlock hm2_5i20.0.gpio.021.in_not => touchy.single-block
    May 2010
    thank you chester
    I understand better now how it's done
  1. touchscreen quits working
    By kendo in forum Tree
    Last Post: 09-14-2009, 07:16 PM
  2. acramatic a2100 touchscreen
    By Julian M in forum Controller & Computer Solutions
    Last Post: 09-10-2008, 01:41 PM
  3. Mach 3 with Touchscreen
    By djgatton in forum Mach Software (ArtSoft software)
    Last Post: 08-04-2008, 08:29 PM
  4. Touchscreen help wanted
    By Max-DK in forum LinuxCNC (formerly EMC2)
    Last Post: 10-26-2006, 01:05 PM
  5. keyboard jog
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-09-2004, 03:17 AM
