587,066 active members*
3,377 visitors online*
    Dec 2004
    26
    image to g code
    Here is what I'm trying to do, I drew a simile image (monochrome) with 2 lines in it that intersect to form a '+'. I want mach 2 to cut that plus
    here are the parameters I'm using
    Raster X/Y - 1 by 1
    Size: 1 by 1
    depth: 0.001
    What I get is not the +, i get some diagonal line. What did I do wrong? I have attached the image and the g code
    Nick
    Attached Files Attached Files
    Thats not the way Mach2 works. It needs to cut the entire image, going back and forth with a small stepover after each pass. I think the diagonal line you see is the rapid move to the start point. The 1 x1 is basically telling Mach2 you want the g-code to be a single point, I believe. What you want to do is raster to vector conversion. You'd need some other software to do that.
  1. Image (Greyscale) to GCODE
    By rackbox in forum OpenSource Software
    Last Post: 02-13-2013, 12:55 PM
  2. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  3. Easily trace an image into your CAD
    By Graphcon in forum News Announcements
    Last Post: 11-14-2003, 01:30 PM
