586,626 active members*
2,381 visitors online*
Hybrid View
    Oct 2006
    158
    Adding a 4030 Driver to the 3-Axis Controller
    Hey everyone,
    For my highschool graduation project I am building Joe's 4x4 Hybrid CNC. I purchased the 3 Axis 4030 Controller last year but the machine requires 4 Axes. I recently purchased an extra 4030 Driver.
    I was wondering if there are any problems with me adding an extra 4030 Driver to the controller? Can the PSU support it?
    Also, how would I go about wiring it and what gauge wire should I use?
    I'll post pictures soon of the current wiring and a wiring diagram and maybe someone can help me add the fourth driver.
    -Spencer
    Quote Originally Posted by Sbthomas13 View Post
    Hey everyone,
    -Spencer
    Pls check here for 4 axis wiring
    http://www.kelinginc.net/KL4030KLDB25Wiring.pdf
    The PS is 36V, 8.8A power supply. what is your 4 motors rated Current?
    http://www.kelinginc.net/NEMA23Motor.html
    Oct 2006
    158
    Thanks for the reply,
    (3) of the motors are the KL23H286-20-8B which are (Rated Current: 2.8A, Rated Voltage: 4.17V (in Bipolar Parallel))
    and
    (1) of the HobbyCNC 200OZ-IN, 3VDC, 3A motor (23-200-DS8)
    Is it okay to mix motors like this?
    Also, where can I get one more of those Quick-Connect panel-mount motor connectors?
  1. 4030 Kellinger driver settings
    By Paul R in forum Automation Technology Products
    Last Post: 09-10-2008, 06:37 PM
  2. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
  3. Help Needed Adding a Third Axis to Techno Inc Controller
    By jlettman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-13-2008, 08:16 PM
  4. KL-4030 driver vs Xylotex as far as performance?
    By cncsonx4 in forum Automation Technology Products
    Last Post: 10-30-2007, 03:22 AM
