586,058 active members*
3,389 visitors online*
    Aug 2006
    118
    Redoing coolant catch
    I'm redoing the coolant catch on my mill in the hopes of more efficient overall design - and one that doesn't leak .
    Chips and coolant are funneled into a bucket, coolant leaks into sump. Chips stay in bucket that is the game plan anyway.
    It's framed in with plywood, cleaned up with bondo and then fiberglassed. Will probably be doing 2 or 3 layers and then painting the entire table.
    The mill will mount to two steel beams that will span across the table.
    Attached Thumbnails Attached Thumbnails rawmillbase.jpg   basefiberglassingrights.jpg
    Jun 2008
    614
    Nice start! hope to see it finished soon, my idea is similar except draining more towards the back and made from sheet metal...
    http://www.g0704.blogspot.com/
    Sep 2006
    1738
    Good job!
    -Jason
  1. Umm... What do you do with old coolant?
    By Driftwood in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2009, 10:12 PM
  2. Umm... what do you do with old coolant?
    By Driftwood in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2009, 10:54 PM
  3. Bridgeport Users - Catch Pan Ideas
    By snakebit95 in forum Bridgeport / Hardinge Mills
    Last Post: 02-05-2008, 10:49 PM
  4. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
  5. What's the catch?
    By Turbine in forum Solidworks
    Last Post: 04-20-2003, 12:50 AM
