What do you mean by VFD normal Motor? as a VFD generally refers to a 3ph induction motor variable frequency drive, generally reserved for the spindle drive.
You can drive one direct from the ICM2900 you need a spare axis analogue output. Do you intend putting an encoder on this motor?
If the encoders you are looking at specify differential output then you should be OK as most use a 8830 or one with similar specs, there are multi voltage ones but most work on 5v.
There are a few models of Heidenhain differential encoders that do not have the line drivers and have a sine wave output. I personally have found that it does not pay to buy used encoders off ebay, make sure they state new,I have been burnt a few times.
Al
Albert E.
