586,106 active members*
3,141 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Scallop Toolpath
Results 1 to 8 of 8
    Oct 2009
    77
    Scallop Toolpath
    I'm trying to understand when to use the scallop toolpath. The definition through the mastercam help to me does not explain it clearly enough for me.
    What does it mean by scallop heights ? and when can I use this toolpath ?
    Thanks for your help in advance.
    Mar 2005
    461
    Scallop heights...
    Lets say you use "scallop" to cut a flat surface with a 3/4 inch ball end mill and your stepover is .100 (very coarse) you will be able to measure the crests and roots of the resulting surface with an indicator. The difference between the crest and root would be the "scallop height". In reality if we were trying to put a fine finish on a part we'd use a much smaller stepover which would result in a much smaller scallop height. I think on most of the electrodes I toolpath my scallop height ends up around .00002
    For my work scallop is rarely useful. It can be helpful when trying to cut numerous faces with angles ranging from very steep to very shallow and provides a consistent stepover at all angles.
    Personally I strongly prefer to use 2 separate operations. SF Contour with shallow paths suppressed (cutting 40° - 90&#176 and then a SF Shallow to hit the remaining areas (0° - 45&#176. Probably over 90% of my surfacing jobs get toolpathed this way.
    May 2005
    2502
    A lot of machinist's calculators and other software will tell you the scallop height given the other parameters.
    In Matt's example, with a few other assumptions, I see a scallop height of 3.4 thousandths. If you wanted that to be a tenth, you'd need a stepover of 0.0173" or 2.3% of the tool's diameter.
    So the calculation is a way to trade sort of a surface finish or accuracy versus stepover and hence the speed. Less stepover will mean more passes to create the surface.
    Cheers,
    BW
    PS I used G-Wizard to do those calcs: http://www.cnccookbook.com/CCGWizard.html
    Oct 2009
    77
    Sorry still do not understand.
    Is it possible to give a pictorial explanation of what scallop heights are ?
    Oct 2009
    77
    I guess my exact question is what does one mean by "scallop" in CNC machining terms..
    May 2005
    2502
    A scallop is the trench like path cut by a ballnosed cutter.
    Try G-Wizard Machinist's Calculator for free:
    Oct 2009
    77
    sorry for my ignorance.. my vocabulary is not that advance.
    I am thinking that using a ballnose cutter for a roughing pass, leaves a trench ( steep mark along the path) and hence a scallop is produced...
    Am I correct ?
    Jun 2005
    305
    Picture Attached
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
  1. Help with toolpath.
    By MagooT in forum Mastercam
    Last Post: 02-20-2010, 02:04 AM
  2. Toolpath
    By mopar499 in forum BobCad-Cam
    Last Post: 05-26-2009, 02:34 PM
  3. Replies: 6
    Last Post: 07-13-2007, 08:05 PM
  4. Replies: 11
    Last Post: 06-01-2007, 04:03 PM
  5. Toolpath set up?
    By Jessica in forum ArtCam Pro
    Last Post: 03-13-2007, 05:13 PM
