586,036 active members*
4,285 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Need Servo Driver ID'd!!! (pics inside)
Results 1 to 8 of 8
    Feb 2007
    32
    They are out of my Anilam/Lagun 2cnc mill.
    if anyone has specific info on these that'd be great!
    I have some documents I got from jerry but there is one wire that is a mystery to me...
    thanks for any info or help!
    -pat
    Attached Thumbnails Attached Thumbnails servoCards 008s.jpg   servoCards 007s.jpg
    24221
    It looks suspiciously like a Westamp, I have the manual on the A651 and the layout and pin connectors look very close.
    EG&G were noted for their relabelling.
    What connector pin does the wire correspond to?
    Al.
    Albert E.
    Feb 2007
    32
    thanks Al!
    any chance I could get a hold of that manual? (assuming its in pdf form).
    the "mystery wire" on the Z and Y cards is one wire going to the 8th pin on the header that receives the analog signal (10th pin if you coulnt the pins that are cut off).
    Thanks!
    -Pat
    edit:
    is this in ref to the same manual?
    http://www.cnczone.com/forums/showthread.php?t=17510
    thanks again!
    24221
    It looks like you have a few more pins on that model, What are you trying to do actually?
    Is this for trouble shooting or re-using them?
    Is there a possibility of tracing the mystery wire back?
    Apart from the analogue signals and some aux power outputs, and of course the commons, the other inputs are usually +- limits, tach and drive-enable.
    The previous post is the one I referred to.
    I have manuals on two different models and in both cases the pin 8 is enable.
    Al.
    Albert E.
    Feb 2007
    32
    Al, I wanted to ask you what you would do in the following situation:
    The drives seem to drift, meaning that when I ground out the analog control signal input, they still move- Adjusting the balance pot has no effect but as a single component seems to function. (I tried adjusting the pot while the input was grounded out with no change in motor behavior. The motor still creeps in one direction at a consistent velocity.)
    I DMM'd the pot while still in the circuit and do see a changing resistance value (without power applied).
    any suggestions or ideas?
    Thanks!
    -pat
    24221
    I know the pots were a notorious source of problem with these amps.
    Rather than spend alot of time on them, I usually ended up changing them for A-M-C or Copley Control drives.
    Al.
    Albert E.
    Feb 2007
    32
    Al.
    sounds expensive.
    would you mind linking me to a source?
    Thanks again.
    -pat
    24221
    This is link to A-M-C, I often look for them on ebay.
    http://www.a-m-c.com/
    You can also use their BLDC drives as they are designed to run DC brushed also.
    This has the advantage that if you lose a motor at a later date, you can upgrade to a BLDC at not extra cost for the drive.
    Al.
    Albert E.
  1. Trying to Identify Servo Drive? see pics
    By gurvy in forum Servo Motors / Drives
    Last Post: 11-22-2008, 11:28 PM
  2. Servo driver
    By karl1 in forum CNC Machine Related Electronics
    Last Post: 03-21-2007, 02:51 PM
  3. M.E. Project (pics, lots of pics)
    By skmetal7 in forum Community Club House
    Last Post: 01-08-2007, 10:30 AM
  4. Setting up my steppers, pics inside.
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 10-15-2005, 06:33 AM
  5. Have almost all my parts (pics), need servo advice
    By Darren_T in forum DIY CNC Router Table Machines
    Last Post: 01-06-2004, 03:20 PM
