I see a bug with Mach 2, if you let's say stop the program(meaning g code program) with the bit still in the work and hit rewind and than hit play. Instead of Mach moving the Z Axis to a safe distance above the work it just does a rapid move and moves X,Y,Z all at the same time. Now if the Z has a slower acceleration than the other axis it will be a bit breaker.
To me Mach should always Z up before doing a rapid move, now maybe all I have stated would not be the case if using switches, but I have not trusted that out yet. One on version their was a problem with drilling and the bit not being clear before rapid moving, but that has since been fixed.
