586,379 active members*
3,606 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal vmc 15 Memory error
Results 1 to 8 of 8
    Nov 2009
    24
    I have a 1995 Fadal vmc 15xt, I have had some people trying to help me get this running, so I am not sure if this is a problem that was created due to inexperience. The message that I get on start up is
    Must enter the backlash table
    Have a version upgrade or memory has been corrupted memory needs to be zeroed.
    Also when I go to the BL command nothing happens.
    Help
    Jul 2009
    317
    Here's what to do:
    DI
    G0 3000
    GO TO OTION #5
    FALLOW INSTRUCTIONS;
    Jul 2009
    317
    HERE'S WHAT TO DO:
    DI (ENTER)
    G0 3000
    GO TO OPTION #5
    FALLOW INSTRUCTIONS
    900
    Daniel --
    The BL command is not show a backlash table because the table does not exist. Also the error message is saying that your memory is corrupted. Follow the attached procedure to correct both issues.
    Neal
    Attached Files Attached Files
    Nov 2009
    24
    Thanks a bunch, this fixed the problem. If there is someone in the Phoenix,Az location that would be willing to give a day of training on this machine please contact me. Thanks
    Dec 2013
    11
    I have kind of the same problem.
    My CNC is a Fadal VMC 15 the last time I upgrade the memory was on 1996.
    My display show this message:
    "YOU HAVE A VERSION UPGRADE OR MEMORY HAS BEEN CORRUPTED"
    "MEMORY NEEDS TO BE ZEROED"
    Aug 2014
    11
    Re: Fadal vmc 15 Memory error
    Hi, did you got this sorted out? I have the same issue, and nothing is moving on the machine not a single axis, and jog is not possible.
    Dec 2013
    11
    Yes I've got the answer is a really stupid thing but worked for me I hope you have the same luck!!!!
    The parameter for "ballscrew pitch" is set wrong. At ENTER NEXT COMMAND, type SETP, hit the space bar (or P key) to page 3, use the enter key to move the asterisk to the ballscrew pitch parameter, change it to INCH. Power cycle the machine.
    Let me know.
  1. Fadal zero memory procedure again.
    By kappullen in forum Fadal
    Last Post: 09-13-2011, 06:26 PM
  2. Rediculous Fadal prices on memory
    By carbidecraters in forum Fadal
    Last Post: 01-04-2011, 08:03 PM
  3. Fadal 5020A RS232 and memory
    By tc26 in forum Fadal
    Last Post: 08-28-2010, 02:28 AM
  4. Fadal Memory Error
    By Antonio Arguijo in forum Fadal
    Last Post: 06-23-2010, 06:22 PM
