587,004 active members*
2,772 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > NKEA22 electric paint sprayer airless paint sprayer coating machine piston pump
Results 1 to 1 of 1
    Delivery: 2.2L/Min
    Max Tip Size: 0.017 Inches
    Working Pressure: 5 MPa~20 MPa (50 Bar~200 Bar)
    Motor Power: 1.0 kW
    Power Source: 220V/50Hz or 110V/60Hz
    Lubricating Oil: ISO VG46
    Packing Size: 480mm*445mm*470mm
    Weight: 26 KGS
    Features:
    1. Small size, light weight, and easy to carry.
    2. Adopts military DC electric motor, high quality, strong power, good performance.
    3. Intelligent electronic control mode by computer chip, LCD displayer for pressure.
    4. Pressure compensation automaticlly, Electronic-Watchdog for protecting motor online
    5. Special Seals imported from Germany. Piston materials with special enhanced treatment, making sure high hardness, corrosion-resistant, super wear-resistant,and long lifetime.
    6. Easy Out design filters from the inside out so filters won’t get stuck or collapse when dirty
    7. Small pulsation, top quality painting film, no bubbles, no impurities.
    8. High spraying efficency, less pollution, low noise
    Company name: Chongqing Nakin Co., Ltd
    Address: No.1 Aoti Road, Jiulongpo District, Chongqing,China
    Website: http://www.paintsprayercn.com
    Tel: 0086 23 68089507 Fax: 0086 23 68089506
    Email / MSN: [email protected]
    Email / Yahoo: [email protected]
    Email / gmail(google talk): [email protected]
    Skype: annaw127
  1. Replies: 0
    Last Post: 11-02-2009, 06:49 AM
  2. NK-WP73 airless paint sprayer adopting mechanism-direction-chang
    By paintsprayer in forum News Announcements
    Last Post: 08-04-2009, 04:35 AM
  3. NK-WJ46 airless paint sprayer with air-driven type
    Last Post: 08-04-2009, 04:32 AM
  4. NK-EA22 airless paint sprayer with electric-driven high-pressure
    Last Post: 08-04-2009, 04:24 AM
  5. 20 ton die cast sprayer
    By Apresto in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2009, 06:28 PM
