Originally Posted by
Ted383
I bought this machine new 3 mos back. Not long after I got it a problem started. The torch would touch off, then cut the lead-in plus about one inch then turn off, a split second later the motion would also stop. The air pressure regulator LED's on the Thermodyne double as an error code indicator. Every time the torch shuts down it shows a "85 psi" error. I will list them later. The problem would occur in manual mode also.
After a long 3 way phone call the PlasmaRoute and Thermodyne techs determined the problem was with the plasma unit and told me to take it to an authorized repair center.
So I did. The tech said he found a bad curuit board. About 2wks later I'm back up and running.
Well now the problem is back. It is behaving exactly as before. The problem is intermittent. It will either cut the entire part correctly or cut one inch and turn off. The one thing that is 100% consistent is that the torch always turns off at the start, never later in the program.
I am beginning to wonder if there ever was a problem with the plasma unit. Any ideas? -ted
PlasmaRoute 4x8 watertable
Thermal Dynamics A80
MP3000
Mach3 R3.042.020
SheetCAM
steppers
