586,556 active members*
3,274 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Are lathe offset values on radius or diameter?
Results 1 to 6 of 6
    Feb 2006
    1792
    Are the offset distances on a lathe always radial values even if we are using diameter programming?
    In other words, if we increase the wear offset by 0.01, will the machined diameter increase by 0.01 or 0.02?
    Mar 2004
    1543
    On my lathe its radius and negative. make offset more negative by .0005 to increase diameter by .001. I got a note on the machine to not screw up.
    Karl
    Aug 2007
    339
    To be sure of what you have just run a teast part and measure it against what you programmed.
    We all live in Tents! Some live in content others live in discontent.
    May 2007
    1003
    When I first started working on lathes, they were programmed in radius and the offsets were in radius. All our lathes are now programmed in diameter, and all offsets are in diameter.
    Jan 2008
    89
    It would seem to me that if you program in dia. the offsets should be the same. I think the machine can be set to either depending on your preference. Although dia. should allow finer resolution. As .0001" rad. is .0002" dia.. We had a Robodrill installed that was set to rad. for tool dia offsets.....Silly giving up the finer resolution. A simple parameter change later and better parts
    As before mentioned a test part will tell you what you are dealing with. And if it is rad. I would call your dealer or the man. and find the parameter to change to dia.
    Feb 2006
    1792
    You are right.
    I checked on 0i Mate TC (I started this thread because I wanted to save my time!). My machine (rear-type lathe) uses diameter programming. So, all offset distances are diameter values.
    Moreover, when I specify a negative wear offset (which was initially 0), it pulls the tool towards the spindle axis by the specified amount, without changing the coordinate display. This means that a smaller diameter would be obtained for the same program. So, to compensate for tool wear (which gives larger OD than the programmed value), a negative wear offset value should be specified, in case of OD machining on a rear-type lathe.
    Am I right?
  1. measuring a diameter by x & y point values
    By Doug Tyler in forum Calibration / Measurement
    Last Post: 01-05-2008, 12:18 AM
  2. Changing Radius To I And J Values
    By macca_loto in forum Mastercam
    Last Post: 10-02-2007, 05:23 AM
  3. Offset values get changed
    By sab in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2007, 05:42 AM
  4. wire offset values
    By Stevatome in forum Fanuc
    Last Post: 03-09-2007, 02:42 PM
  5. Replies: 1
    Last Post: 02-21-2007, 10:57 PM
